Generally 30-35 is acceptable. Lots of people do 32 "to be safe."
When the dealership realigned my Z51 for street driving, I asked them to changed it to 32 cold in preparation for the upcoming colder weather. My goal is to aim for 30-32 cold. My theory is this is the best average between comfortable ride and MPG.
PSI on the sidewall is maximum pressure. The pressure in the door jam is the correct tire pressure from the manufacturer. According to the owners manual - 4 PSI for maximum traction.
Sorry, I should have been more clear. I run 32 psi cold in my vehicles. My reference to the tire sidewall specs was meant to be understood as I would not exceed the psi indicated on the tire sidewall.
Also, reducing tire pressure by 4 lbs may allow for slightly better traction, but it will also increase wear and reduce fuel economy.
My 2015 Z51 convertible is pumped to 30 lbs. After a few miles, those pressures increase to about 34 psi. Tire wear and traction seem good with the tires inflated to this pressure...
My 2015 Z06 door pillar says 30psi cold front and rear. During hot days I have seen my tire pressure run as high 38psi .
My 2014 Impala 2LTZ the door piller says 33psi cold front and rear you would think chevrolet would stick to even tire pressures . So I run it at 35 psi
It doesn't as long as you don't exceed 50 mph. For most Corvette driver this doesn't pose a problem. Best handling at 26 psi cold. Higher than 30 puts increased stress on wheels when you hit potholes.
