X-Pipe installation
Old Oct 15, 2016 | 11:35 AM
DONPAT's Avatar
DONPAT
Default X-Pipe installation
Can anyone recommend a shop in the Chicago area to have a Borla x pipe 60547 installed?
Thank you.
Old Oct 15, 2016 | 11:55 AM
CSTYLE's Avatar
CSTYLE
Speed inc
Old Oct 15, 2016 | 01:30 PM
joemessman's Avatar
joemessman
Make sure they don't use any welding on it. If they do run for the exit!
Old Oct 15, 2016 | 04:04 PM
joemessman's Avatar
joemessman
Old Oct 15, 2016 | 04:10 PM
sTz's Avatar
sTz
Just an FYI: I installed a cat-back system in my garage using just ramps. The mufflers were the most difficult as the rear valance has to be removed, but the actual X pipe installation was very easy.
Old Oct 15, 2016 | 05:07 PM
KratosBear's Avatar
KratosBear
Why not weld? Wouldn't that be better?
Old Oct 15, 2016 | 05:14 PM
BJ67's Avatar
BJ67
Its a complete bolt on, easy off, easy on just like the factory xpipe. Do it yourself.
Old Oct 15, 2016 | 05:59 PM
joemessman's Avatar
joemessman
You do not need to weld it because it bolts on and off. You may want to change back or do something else in the future. And if you have access to a lift, or a way to get under the car it is easy to do yourself. I did it myself and I can barely screw in a light bulb. And you are going to love that sound!
To X-Pipe installation
