Ebrake doesn't release sometimes
Whenever I run across someone who responds the way you did in this thread after seeking assistance, I just make a note to not respond in the future to that individual's questions.
Now I'm sure you'll hide behind the "well if you're gonna be rude I won't answer you" but I'd really like to know why you think my response here was rude.
1) I know this was not your main point, but you mention keeping the clutch depressed when sitting at the light. You should never have the clutch depressed unless you are shifting if you want your clutch bearings to last. Sitting at a light with the clutch depressed puts a lot of strain on the bearings and springs in a clutch. Put the car in neutral and take your foot off the clutch pedal at lights.
2) About taking both feet off the pedals at the light and letting the e-brake hold the car... This is not safe, as your brake lights are not on and you are asking to be rear-ended by an inattentive driver.
I also believe that the automated e-brake release is not intended to be a part of your everyday driving routine. I believe it was put in to help prevent the wear that can occur if a person forgets to disengage it and drives away. If you intend to use it for purposes other than what it was intended for, you cannot expect straightforward analysis of your problem.
Please give the people responding a break...they are trying to help, but were responding to an unusual (and difficult to understand) request.
The ebrake is a mechanical device with moving parts, and in your situation is interacting with very hot metal and pad material. It is not meant to be engaged and released regularly when driving while all of the brake parts are heated up. I'm not surprised that it occasionally sticks and I doubt that the dealer can do anything about it given how you are using it.
I would add that the OP is asking strangers on the internet to diagnose a problem with his car and getting upset because that's not happening. A dealer can diagnose a problem; strangers on the internet can't.
Look I posted here to see if others experience this problem (some do) and what they do to work around it. Obviously there are some inputs into the system to say when the ebrake should release and when it shouldn't. I'm just asking what those inputs are.
PLONK.
PLONK.
Your parking brake (it's not an emergency brake BTW) isn't working as it's supposed to. Go to a dealer and have them diagnose and fix it.
/thread
As for it being "cold", this happens sometimes after driving for tens of minutes if not hours so that's not it either. Indeed, as falconhulk says, it doesn't even ever(?) work for him.
BTW falconhulk, my experimentation shows me that unless the ebrake was engaged when you left the car, when you return and attempt to start the car, your seat will not go to the set position. If your ebrake never works you must experience this a lot!
The small surface area of the shoe plus the fact it's only on the rear shows that it is really a parking brake and not an emergency brake (as it would be terrible for stopping the car in emergency situations.) Nowhere in the manual does it refer to it as "emergency brake" however, it does talk about using the EPB while in motion, it just doesn't say why.
If when taking off, the EPB tries to disengage but is unable, I'd think the shoe is sticking somewhere and see if maybe some rust is causing it to stick. This isn't terribly uncommon for drum brakes, especially those of parking variety which don't get used to stop the vehicle, but generally just to hold it in place. However, the C7 knows about this, and may cycle the EPB (while stopped) if the driver hasn't in a while. (This is an assumption, as once again, the manual doesn't say "why" this is intended behavior.)
However, if when taking off, the failure is that the EPB doesn't even try to disengage, then I'd start pointing my finger at the control module.
Look, I already referred to the manual before. It was asked is it a parking brake or an emergency brake - there is none (https://goo.gl/U7QR6G), further as I read in the manuel last time I came across the statement cited above.
Now let's make up some more stuff that I didn't say...
On page 191 of the manual:
Ergo the parking brake can be used in an emergency.
Geeze what crawled up your *** today? No, Mr. Strawman, I never said I was super intelligent, in fact I haven't even said I was smart. So don't you go stuffing words in my mouth and then attempt to shoot me down for saying it, it only makes you look foolish. This are discussion forums and I'm discussing this issue.
Hmmm... A couple more strawmen - you appear to be good at them. Now go argue with somebody who actually said such things because it wasn't me - it was your imagination.
