How to remove center caps
Old Nov 7, 2016 | 11:55 AM
brooklync5's Avatar
brooklync5
Default How to remove center caps
Got a new set don't want to ruin my old ones. How do I remove my center caps?
Old Nov 7, 2016 | 12:04 PM
chasboland's Avatar
chasboland
grapple onto it with a suction cup
Old Nov 7, 2016 | 12:11 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
I use black gorilla tape and do what this guy did:
Old Nov 7, 2016 | 12:42 PM
justplainjim's Avatar
justplainjim
Banned Scam/Spammer
Put a piece of tape on the end of a small screw driver to protect the caps and carefully pry them off..
Old Nov 7, 2016 | 01:57 PM
GTFD2's Avatar
GTFD2
Dental Floss
Old Nov 7, 2016 | 02:00 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Originally Posted by GTFD2
Dental Floss
Slide it under the cap and pop it out. Easy Peasy.
Elmer
Old Nov 7, 2016 | 04:19 PM
Dental Floss
That should work very well.
Old Nov 7, 2016 | 04:25 PM
JoeD-C8's Avatar
JoeD-C8
St. Jude Donor '18 thru '25
Works every time!
Old Nov 7, 2016 | 05:00 PM
65vette396's Avatar
65vette396
Only use dental floss. Wrap it around the cap and cross the 2 ends and pull. It comes right off with little effort and no mars on the cap.
Old Nov 7, 2016 | 07:44 PM
coupeguyz51's Avatar
coupeguyz51
sometimes, the simplest solution is the best!
Old Nov 7, 2016 | 08:26 PM
mracer14's Avatar
mracer14
Default Center caps
I have seen it done with a credit card.
Old Nov 7, 2016 | 09:34 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Take the wheel off and lightly tap the back side of it with a rubber hammer handle.
Old Nov 7, 2016 | 10:40 PM
bjones7131's Avatar
bjones7131
Yea, i had a 70+ year old lady use a credit card to remove center caps. She said she saw them do it at the museum.
Old Nov 20, 2016 | 12:49 AM
996toomey's Avatar
996toomey
I am not understanding how you wrap the dental floss or insert it through the cap?
Old Nov 20, 2016 | 12:54 AM
Foosh's Avatar
Foosh
You don't insert it through the cap. Just insert it under the edge of the cap 1/2 or 3/4 way around and gently pull it toward you. It's not much different than inserting floss in those tight tooth gaps.
I just changed all 4 wheels and tires, swapping my summers for all seasons, and the lightest finger push from behind also pops the caps out. Thus, you won't have to pull hard on the floss.
Old Nov 20, 2016 | 09:04 AM
396tears's Avatar
396tears
Use a plastic gift or credit card. Insert one corner and work your way around the cap and it will come out. Very easy and safe.
Old Nov 20, 2016 | 11:10 AM
eboggs_jkvl
Moderator emeritus
I just went out and popped one off with dental floss. push the floss in with your finger nail and pry out ever so slightly as you slide the floss in. pull it to mid center, tie a knot and pull. Off comes the cap. I also did it with an old credit card. I also got it off using the right twin prong side of this trim tool.
Elmer
To How to remove center caps
Old Nov 20, 2016 | 11:40 AM
Foosh's Avatar
Foosh
BTW, plastic trim tools such as pictured above are very handy to have. They don't scratch paint if you're gentle, and I use them for all kinds of little tasks other than car stuff. An entire set of different shapes and sizes is available on Amazon for $6.
https://www.amazon.com/KINGLAKE-Pane...+removal+tools
Old Jun 15, 2017 | 09:53 PM
Z06NJ's Avatar
Z06NJ
To contribute to this thread- I used this something like this:
https://images.search.yahoo.com/imag...ad&fr2=piv-web
Old Jun 16, 2017 | 11:40 AM
iclick's Avatar
iclick
I tried floss but it broke every time, probably a matter of my habit of buying cheap floss. I use 8-10# fishing line now which works fine and never breaks. I shove it in the gaps with a toothpick.
