A8 Issues
Old Nov 19, 2016 | 03:51 PM
Ed Ramberger's Avatar
Ed Ramberger
5,900 miles - started car after sitting and put in reverse - just creeped - no firm engagement as it had done every start until then. Also, all the warble noises appear only to be in A8 cars.
Shifts amazing - awesome. I think there are still bugs though. Maybe software, maybe physical.
Old Nov 19, 2016 | 06:50 PM
iclick's Avatar
iclick
Originally Posted by Ernest_T
GM says's its the torque converter locking and unlocking. I'm not an automatic transmission expert, but I think its supposed to stay locked over a certain speed and remain locked unless engine load requires the AFM to go to into V8 mode.
If it is the TC is supposed to lock in AFM (V4), why does RPM decrease when it goes into V8 mode as in my case? You would think if the TC locks, RPM would go down. So is GM saying the TC is locking-unlocking so fast it creates a shudder? I'd also like for them to explain how the tach oscillation factors into this?
There have been suggestions on other threads the shudder might in fact be a faulty design of the telt tensioner. Another is faulty AFM lifters, both of which sound more likely linked to a drivetrain shudder than the TC--but I'm using old-school mechanical principles in trying to sort this out. Since changing the TC doesn't seem to fix the shudder in many cases after a moderate time interval, I'm still thinking GM doesn't have a grip on this problem.
As that said, I must say that my A8 otherwise performs impeccably.
Old Nov 19, 2016 | 10:52 PM
david.a8.z51's Avatar
david.a8.z51
Originally Posted by Scruff Vette
Over 7,000 miles on my base '16 A8 and not one transmission issue. After owning a dozen Corvettes C2-C6 with three pedals I would not go back to a manual again. My A8 is that good.
​​​​​​​mine was perfect til 24k. Then the converter went bye bye.
Old Nov 20, 2016 | 10:21 AM
bjones7131's Avatar
bjones7131
Originally Posted by Kwagnerhvac
I didn't. Where do I find it?
I was the author of the Warble post and our issues didn't include anything but the warble type noise at or very close to 1500 RPM when on an incline and slight acceleration. Still no answer to this problem. GM has bought back a car and are in the process of disecting it to determine cause. So for 99% of the cars are base stingray A8 tranny. Good luck with your issue
Old Nov 20, 2016 | 11:45 AM
Ernest_T's Avatar
Ernest_T
My car didn't shudder for 9000 miles, I had the TC replaced at 12000 miles and it didn't shudder for about 1000 miles, then started again. It drives and shifts great in V8 mode, but is really annoying in V4 mode. It's a strange phenomenon. A significant number of cars shudder, but the great majority don't. I'm with you on thinking GM doesn't know what's going on.
Old Nov 20, 2016 | 11:48 AM
capecodvette's Avatar
capecodvette
For the record, my 2016 Stingray Z51, A8 (built 10/15) has no issues. The A8 shifts as designed, the algorithm's built into the learning software work as designed.
Bottom line, no issues.
Old Nov 20, 2016 | 11:59 AM
Ernest_T's Avatar
Ernest_T
how many miles?
Old Nov 20, 2016 | 12:01 PM
joemessman's Avatar
joemessman
how many miles?
I have the same build date as the Oct 15 guy and have 22,000 miles on mine and never had a problem. Hope you get fixed up pretty soon.
Old Nov 20, 2016 | 10:22 PM
pkincy's Avatar
pkincy
Originally Posted by Hilton Head Vette
I am having some of the same issues with my '16 Z51. Weather in sport or any of the other modes besides track I can watch my tach move up and down about 200 rpm's. I'm not all that crazy about having some tech at my local dealership rip half of my car apart just to replace the converter or transmission. With only 2400 miles i can sit on it until it gets worse. What I did find is that no matter what mode Im in if I put it in Manual mode everything smoothes out. Today I was on I95 down here in SC and decided to drop it in Manual while driving in Touring, whala no tach movement or feelings through the pedal. That tells me that there may be FMS issues as well as transmission/torque converter. First off I didn't buy a performance car to have it go into V4 mode at any time. I asked the Tech Nerd in Corvette Mag about it and he was vague. Had to laugh when he said that if I was worried about the transmission maybe I should sell the car and get something else. This is my 7th Vette and Id rather fight than switch...
Sure sounds like normal operation with the car going from V8 to V4 at part throttle. In M mode it won't do that so it smooths out. You can go to Range Technology or several of our vendors and buy their product to prevent V4 from engaging.
Old Nov 20, 2016 | 10:32 PM
thejuice401's Avatar
thejuice401
what you guys suggest honestly.. the new a8 transmission? or the a6? looking to purchase another a vet that ill be keeping forever and wanna deal with the least non sense as possible
Old Nov 20, 2016 | 10:35 PM
pkincy's Avatar
pkincy
I love mine. Does everything I could possibly want. It shifts for me when I want it to whether that is when I want to go slow or go fast and it lets me do the shifting when I feel like it and want to keep the revs up to hear the exhaust with the valves open.
Old Nov 21, 2016 | 08:05 AM
dead of night's Avatar
dead of night
For a new buyer, what is the best thing to do if I want a C7 with an A8 transmission?
Old Nov 21, 2016 | 08:23 AM
  #33
road-rocket's Avatar
road-rocket
The 2017 versions of the A8 are pretty good. It's the AFM I'm having trouble with on my 17 now that I never had an issue with on my former 2015. Like trading one issue for another.
Old Nov 21, 2016 | 09:14 AM
  #34
Red C8 of Jax's Avatar
Red C8 of Jax
Buy a 2017 car and drive the Sh$$ out of it. Buy the extended GM warranty if you plan to keep the car longer than the powertrain warranty. It appears most of the A8 problems involving the torque converters occurred in the 15 and early 16 cars. I would have no problem buying a 2017 A8 car.
Old Nov 21, 2016 | 09:29 AM
  #35
bbcb's Avatar
bbcb
Lets be honest and opened minded ....
Just the fact that this thread exists and continues , should answer ALL questions regarding the purchase of an A8 .
Sure cars may have rattles and noises ..even sub-par paint jobs at times.
But ongoing tranny problems and complaints ...for the most part not being corrected,should be a evidence enough to question a purchase of the size.
Old Nov 21, 2016 | 11:47 AM
  #36
joemessman's Avatar
joemessman
I agree with you. Even though the vast majority of drivers haven't had the issue, there are too many. I believe the main issue is defective parts installed. Poor quality control in regard to the company that supplies the parts maybe. I, and most others, have found the A8 to be fine so far. I have 22K on mine, that has a 10/15 build date, and it has been terrific. I drive the **** out of it too. Never any of the issues that some have had. And the fact that a few 2017 are having issues, and I mean very few, makes you wonder what part, or combination of defective parts is contributing to this.
Old Nov 21, 2016 | 11:50 AM
  #37
thejuice401
lol the more i read these threads the least i want to buy a corvette now. god damn you gm!!!
To A8 Issues
Old Nov 21, 2016 | 12:16 PM
  #38
dead of night
2017's are having the same issue?
Old Nov 21, 2016 | 12:22 PM
  #39
joemessman's Avatar
joemessman
I have seen 2 or 3 reports of the issue on various forums. That is not many cars out of all that have sold, but too many in my opinion.
Old Nov 21, 2016 | 12:38 PM
  #40
iclick's Avatar
iclick
That doesn't sound encouraging. My car shuddered intermittently on the way back from the dealership with <50 miles on the clock. My first thought was a faulty u-joint, but I only noticed it again sporadically until a year later, and lately (past month) it has become the new normal anytime V4 is enabled under light acceleration.
Since this and minor tach oscillation is currently my only issue that may or may not be linked to the A8, my plan is to let it go until I can get some indication the problem has been finally isolated and a categorical fix effected by GM.
