Issues with 2014 Corvette....help
Old Nov 13, 2016 | 10:50 AM
Rocker 56's Avatar
Rocker 56
Default Issues with 2014 Corvette....help
gauges flickered... wont start, window doesn't go up or down when opening the door... car sat for a while but was on tender.. anyone know if this is a battery issue or programing issue?
Old Nov 13, 2016 | 10:57 AM
BELVIN20's Avatar
BELVIN20
Being a 2014 & if original battery, I would replace battery before I did anything else
Old Nov 13, 2016 | 11:09 AM
Rocker 56's Avatar
Rocker 56
that's what I'm thinking
thanks
Old Nov 13, 2016 | 11:10 AM
Rocker 56's Avatar
Rocker 56
its my cousins car and hes stuck.. going to try and get a jump start to get home.
Old Nov 13, 2016 | 11:20 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Could be the alternator also. If it is still under warranty why not take it to the dealer?
Old Nov 13, 2016 | 11:25 AM
vettnutt's Avatar
vettnutt
Was the battery tender plugged into the rear receptacle?
Old Nov 13, 2016 | 11:26 AM
Fat Mike's Avatar
Fat Mike
Easy test if you have a volt meter. But, if you don't, I would suspect battery.
Old Nov 13, 2016 | 11:36 PM
Rocker 56's Avatar
Rocker 56
took it to dealer last week.. drove it all weekend and had an issue again today.. turns out the negative terminal was loose. tightened it and all is good. Question is how did that happen.. since it just went to the dealer.. u make the call. Thanks for all your comments..
Old Nov 13, 2016 | 11:48 PM
Foosh's Avatar
Foosh
Loose or bad grounds are always one of the first things to look for when experiencing electrical issues.
Old Nov 14, 2016 | 09:15 AM
justplainjim's Avatar
justplainjim
Banned Scam/Spammer
There is a slight chance that the tender is bad or plugged into the wrong socket. After he gets it home give the battery a good charge on a charger and not a tender. If problem persists then get a new battery.
Old Nov 14, 2016 | 12:48 PM
Duntov7's Avatar
Duntov7
Originally Posted by Rocker 56
drove it all weekend and had an issue again today.. turns out the negative terminal was loose. tightened it and all is good. Question is how did that happen....
Well, my battery's negative terminal was "loose" after a trek up the infamous Pike's Peak road course up the mountain....a few years back in a C6....before the top section of the championship track was paved....felt like a log-road...awful....loosened my teeth too.
Old Nov 14, 2016 | 08:58 PM
bigblock427's Avatar
bigblock427
A similar thing happened to me in my 2010 GS. Just tightened up the connection and all of the issues went away.
Old Nov 15, 2016 | 05:59 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
This is one place where a Volt meter may not provide the answer. It draws very little amperage and a high resistance path, due to loose ground connection, may still show high voltage until a high current load, like starting, is applied.
Have that issue with 12 volt readings on my outdoor inground lights that show 12 volts at the socket but won't light a bulb! Usually a high resistance, corroded light fixture wire to main line mechanical connection. After 20 years, believe I have soldered most of those by now!
Bit funny with the C7 as the cable to battery connections are a better than old designs. But they must be tight to start!
To Issues with 2014 Corvette....help
