No key detected???
Old Nov 13, 2016 | 11:45 AM
C7HOORAY's Avatar
C7HOORAY
Default No key detected???
My 14 C7 has let me down a little. When starting the car I get a message in the DIC "No key detected - insert key in slot to start". I have used both key fobs to no avail. Car does not recognize either of them. I installed a new FOB battery in one of them - but problem is still there. Car starts, but never recognizes either of the factory supplied keys with my car...2 years and not a problem at all until this. Anyone else encounter this? Have a cure? I can go to the dealer this week, but it's a hassle going there that I would like to avoid...
Old Nov 13, 2016 | 01:17 PM
RonC7's Avatar
RonC7
Replace your key fob battery...
Also - the car battery may be failing at 2 or 3 yr old.
Low voltage causes strange things.
Old Nov 13, 2016 | 01:45 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
Hooray, I had the same thing happen. I just replaced my key FOB battery and the problem was resolved.
Old Nov 13, 2016 | 02:14 PM
owc6's Avatar
owc6
Sometimes there is some interference that can cause the car to not recognize the fob. Cell phones, local security systems, coins or a lot of keys in the pocket, etc… I have a couple purses with really strong magnet clasps that interfere, too.
Old Nov 13, 2016 | 02:29 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
RKE not detected? Use the table:
http://www.ls2.com/boggs/c7/C7RKENot...dchecklist.pdf
Elmer
Old Nov 13, 2016 | 02:45 PM
C7HOORAY's Avatar
C7HOORAY
Default I'm on it...
Elmer
All of these are good, helpful suggestions....I'm on it!
Old Nov 13, 2016 | 03:52 PM
dvilin's Avatar
dvilin
Double check and make sure you put the new Fob battery in correctly and do a load check on your car battery.
To No key detected???
