Corvette storage
Old Nov 18, 2016 | 05:12 PM
PegasusCapital's Avatar
PegasusCapital
CF Senior Member
Put it on Race Ramps FlatStoppers. Gets it up off the concrete and keeps the run flat tires from developing a flat spot.
Old Nov 19, 2016 | 06:14 PM
JoeD-C8's Avatar
JoeD-C8
St. Jude Donor '18 thru '25
1/2 tank of gas with Stabil, trickle charger and fresh oil.
Old Nov 19, 2016 | 06:17 PM
JoeD-C8's Avatar
JoeD-C8
Originally Posted by Levonotar
Don't store it drive it
I live in the Northeast where amateur hour includes soccer moms driving Yukons at full speed. No thanks.
Old Nov 19, 2016 | 07:20 PM
funz06's Avatar
funz06
Originally Posted by atvBob
For those in the midwest and northern states who store in an unheated garage, do you put your C7 on blocks to get the tires off the ground? If so, any tips on what to do/not to do?
I am in an unheated garage in New England. Historically, I never put anything under the tires---the car just sat on the concrete floor from late November until late March--never had a problem with flat spots. I over inflate the tires by some 7-8 psi-------think the psi called for on the door jam is 30 psi, and I filled them to between 36 and 38 psi or so this year. I will check the psi in late January. I have 'heard' from what seemed to be reliable sources that even if I did get a flat spot, it would go away within the 1st 100 miles of driving (and probably after just some 20 miles or so). With these C7 Z06 tires---the key is not to move the car at all----just let it sit to avoid the tires cracking.
Now this year----because we always look for ways to spend money on these cars-----I bought a piece of 4' x 8' 1/2 inch Styrofoam insulation at Lowe's and cut it in 4 equal pieces------then I put one piece under each tire. I don't know why I did this-----probably from reading too many posts about getting the tires off the concrete----I caved.
I have always filled the gas tank, with no Stabil or anything added---did so again this year. Then 2 days ago my son-in-law tells me he stores his older Cadillac with next to no gas. He said he has always done this, as has everyone in his family------he said nobody ever had a problem?????? His uncles always said either fill the tank or leave it empty........most in his family leave it as empty as possible.
I only put about 2,500 to 4,000 miles on the car each season. I let the car sit for the 3-4 winter months with the existing oil in it------then I have the oil changed in late March or early April for the new season. I think I read somewhere that about 60% of the owners change their oil before storing it away for the winter, and 40% change it to start the new season................I bet there are some that probably do it both times.
I also put those Bounce dryer sheets under the hood (3-4); one on each tire; one at the base of each tire; I cover the exhaust pipes with some of that garden cloth that helps prevent weeds from growing (use twine to tie it around the exhaust pipe openings---and I put a Bounce sheet on top); hook up the battery tender; drape the car with the 4 huge bed comforters I have been using for 15 years.............and then curse GM and Michelen all winter for not providing us with all season run flats (even all season non-run flats) for these great cars.
Old Nov 20, 2016 | 12:03 PM
Patman's Avatar
Patman
I sure hope there aren't too many people on here doing that, what a massive waste of money! (especially if you have a dry sump car, and are throwing away 9+ quarts of brand new perfectly good oil)
Old Nov 20, 2016 | 12:23 PM
KGS365's Avatar
KGS365
Default what with the bounce sheets
whats with the bounce sheets for mice?
Old Nov 20, 2016 | 06:00 PM
funz06's Avatar
funz06
I read it on one of the Corvette forums 2-3 years ago........so it must be accurate, right? But seriously, I did read on one of the Forums (maybe the C6 general discussion), and figured what do I have to lose......so I did it last year and again this year. The story is that the mice don't like the smell and they move on.
Old Nov 20, 2016 | 07:27 PM
KemahGT's Avatar
KemahGT
They say moth ***** work well too. If Bounce works I think I would prefer my car smelling like Bounce instead of my grandmothers house!
No offense granny!
Old Nov 20, 2016 | 08:33 PM
B&BVettes's Avatar
B&BVettes
I top off all fluids(inc. gas), over inflate the tires to 40 lbs, add StaBil, clean, detail, plug-in and cover. Never had a problem.
Old Nov 20, 2016 | 09:03 PM
HurstSRT's Avatar
HurstSRT
Bounce sheets work well keeping mice away. So does peppermint oil on cotton *****. Most animals are very sensitive to peppermint. Had to use it years back.
Old Jan 18, 2017 | 12:36 PM
Chevette!?!?'s Avatar
Chevette!?!?
Originally Posted by DFA
I've read that when you store your C7 only leave a little fuel in it and I have read full it up before storage. With all my other vettes I have filled the tank before storing. What is everyone's opinion.
Thanks,
Steve
The engineers tell you that (1/4 tank) because it almost guarantees you'll fill it with fresh gas in the Springtime!
Old Jan 18, 2017 | 01:38 PM
Boiler_81's Avatar
Boiler_81
No need in my opinion. I stored mine last year. When I took it out in the Spring there was a very slight flat spot which when away within a mile of driving.
Old Jan 18, 2017 | 07:29 PM
  #33
JoesC5's Avatar
JoesC5
Pick up a cheap mist sprayer(for potted plants) at Walmart and spray the diluted (50/50 with water) peppermint oil on the floor around the car and on the tires and around any openings where mice might try and enter the garage. Re-spray the peppermint oil every month or so.
Also don't store things that mice can use for bedding in your garage and don't keep dry pet food in open containers(use a metal can with a metal lid).
