2014 Stingray wheels
Old Nov 23, 2016 | 01:44 AM
Abul's Avatar
Abul
Default 2014 Stingray wheels
Hi,
I am looking to put after market wheels and wanted to know if putting 19X10.5 in the rears will have any damaging effect. Will an extra .5 on the rim with stock tires make the tires stick out or rub against the body?
Old Nov 23, 2016 | 06:43 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
You can put up to 11" in the back without issues. Just be aware of the offset.
Old Nov 23, 2016 | 10:35 AM
Maxpowers's Avatar
Maxpowers
I have 19x10.5 in the rear for my fall/winter setup and they fit perfectly. If you are purchasing aftermarket wheels be sure to deal with someone that specializes in Corvette (like a forum vendor).
The offsets on the Stingray are extreme as the hub nearly sits out flush with the body.
Old Nov 23, 2016 | 11:11 AM
Eff A Ford's Avatar
Eff A Ford
The maximum width for a 285/35 is 11". The tire will be a little stretched but you should not have any problems. And make sure it's the right offset.
Old Nov 23, 2016 | 03:36 PM
Abul's Avatar
Abul
Hey guys, Thank you so much for your input/advice. I have been into cars since a very long time, but somehow I dont know about this offset issue. Please tell me whats the maximum / minimum I can get away with and I will check with the retailer.
I am interested in wheels by TSW - Monaco
MATTE BLACK W/ GLOSS BLACK LIP.
Also, I am in Pakistan and buying the vette from Chicago, not that I am doing it for the first time, I have a C6, and just recently got a BOSS 302 HPE 700, but I dont know about this offset issue.
I will really appreciate your advice, as Marcus from Waukegan tires Chicago says it just cant work, and they dont have offset sizes etc. mentioned on the website.
Thanks again.
Old Nov 23, 2016 | 03:40 PM
Eff A Ford's Avatar
Eff A Ford
Offset should be low to mid 70s in the rear. Front, low to mid 50s
Old Nov 23, 2016 | 03:49 PM
Abul's Avatar
Abul
Thanks. If you have the time and if offset can be explained in couple of lines, i will appreciate a short offset 101. Otherwise, thanks for the info you have given me.
Old Nov 23, 2016 | 03:59 PM
Eff A Ford's Avatar
Eff A Ford
If i remember correctly, its the distance from the mounting surface of the rim, to the center of the rim width in millimeters.
the higher the offset, the less the wheel sticks out.
The c7, and most exotic cars have a very high offset. You can tell by how for the brakes and wheel hubs sit to the fender.
To 2014 Stingray wheels
