Air Scoops over the rear wheels Z06
Just curious....can the air scoops on the top of the back panels be installed on the Z51? I'm sure they are functional, but they look awesome.
TIA
TIA
Are you talking about the scoops on the top of the rear fenders...? If so, then yes. Many have successfully added this mod.
The lower rear brakes ducts, however, cannot be added unless you go with a wide body mod.
AdventurePoser (11-27-2016)
Thanks, guys, but forgive my ignorance, but how would this be considered a simple mod? Don't openings have to be cut on the top panels?
sTtz, that is a beautiful car!
I didn't realized that you have a convertible. Adding those vents would be difficult. I don't believe that I've ever seen them added to a vert. Hopefully someone else will chime in... GL.
Z06 on top of the fenders on Z51 took und 25 minutes with the help of my body shop owner neighbor.
principalpony (11-28-2016)
Just to let you guys know there is no such thing as a rear fender. It's a quarter panel.
https://m.youtube.com/watch?v=CTR1LdhaksU
Received 1,694 Likes
St. Jude Donor '15
On a convertible those air inlets are under the car.
I would try trunkmonkey or check the for sale section, they pop up there from time to time.
Received 19,303 Likes
'20-'21-'22-'23-'24
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
Well, Vert's don't have scoops because the top mecanizum leaves no room for the air duct- but! You could add them as SMC cuts and drills like butter. Could no doubt carefully cut the hole and insert the grill. None functional but would look the same!
Thanks guys...guess I should have mentioned that I do have a convertible . No fancy air scoops for me!
