2016 Z06 storage
Old Dec 3, 2016 | 12:37 PM
dnomad63's Avatar
dnomad63
Default 2016 Z06 storage
I'm looking to store my car away for the winter (4 month's ) Should I start it up every week? Keep the battery charger that came with the car plugged in and forget about it? Will I get a flat spot on the tires? Anyone with advice? Thanks!
Old Dec 3, 2016 | 01:05 PM
John Micheal Henry's Avatar
John Micheal Henry
Reverse Logic have mats to park on if you're worried about flat spotting your tires. It would probably be a good idea to use the GM trickle battery charger if the car will be parked for four months..
Old Dec 3, 2016 | 01:06 PM
millpond's Avatar
millpond
Do NOT start every week. Just leave the battery maintainer plugged-in. The latest info from GM is to keep the fuel level at 1/4 tank, and add Stabil to the fuel.
Old Dec 3, 2016 | 01:13 PM
Supersonic 427's Avatar
Supersonic 427
I just stored mine 3 weeks ago. This is what I do, but others may do differently. Add air to the tires (to about 40 PSI) install battery tender and don't start till you are getting it out of storage. I also fill the tank with NON Ethanol Premium Gas and usually change the oil, but mine only has 300 miles on it so I did not change it. Coat of wax and cover it up.
Old Dec 3, 2016 | 04:25 PM
dvilin's Avatar
dvilin
Old Dec 3, 2016 | 07:05 PM
sTz's Avatar
sTz
Battery tender and you should be good to go. I don't sweat the other things... I've never had any issues w/fuel, oil, or flat spots. If flat spots occur, then they disappear as soon as the tires heat up. That being said, it'll certainly wouldn't hurt following GM's recommendations.
I agree w/other posters, don't start it once a week... excessive wear, moisture, etc.
Old Dec 5, 2016 | 10:39 AM
JDM111er's Avatar
JDM111er
I just stored from mine 3 weeks ago. This is what I do, but others may do differently. Add air to the tires (to about 40 PSI) install battery tender and don't start till you are getting it out of storage. I also fill the tank with NON Ethanol Premium Gas and usually change the oil, but mine only has 300 miles on it so I did not change it. Coat of wax and cover it up.
Old Dec 5, 2016 | 10:47 AM
Boiler_81's Avatar
Boiler_81
I have been storing toy cars for decades. I wash it, drive it for a short time to make sure the brakes are dry then park it and put the battery on a tender. I have never had an issue with this method. In my opinion anything else is not necessary.
In the Spring, I check the tire pressure, remove the tender and wash then drive.
To 2016 Z06 storage
