C7 M7 question
Old Dec 18, 2016 | 03:15 PM
spireland's Avatar
spireland
Default C7 M7 question
I'm strongly considering picking up a C7 in the spring as a second car/toy, so I finally test drove one yesterday, a used 2015 Z51 yesterday. The manual felt a bit clunky, and I had a hard time getting shifting into 2nd.
This was a pretty new car, about 1500 miles, and it was cold outside, though it felt kind of strange that it should be tough to go in. I've driven manuals most of my life, this would be my sixth (though mostly honda's and mustangs, this would be my first vette) and it just felt hard to go into gear, for lack of a better description. Is that typical with the C7 M7?
It could have just been the car, it was early in the morning, mid 30's and the car didn't really warm up as it was only a ten minute drive. I'm planning on finding some others to drive, though I'm just curious to hear from other drivers if this is typical or anyone had a similar experience and you just have to get used it?
Thanks!
Old Dec 18, 2016 | 03:20 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
It might have needed a warm up....
KGS365's Avatar
KGS365
thats strange i drove a rental z51 with 17,000 miles and the manual trans was a smooth as butter, great positive clutch engagement..I was thinking to myself if its this good at 17,000 miles then buying a used car with under 10,000 would be no risk
Old Dec 18, 2016 | 03:24 PM
Zaphod B's Avatar
Zaphod B
Many forum members have indicated that their M7 transmissions have a balky 1-2 shift until the car is well warmed.
Mine is the same at 4000 miles. 1-2 shifts in cold weather with a cold car are damned near impossible unless you force it, which I don't like to do. Instead, I skip shift to 3rd until the transmission has some heat in it.
Edit: based on KGS365's comment I'm thinking that this behavior may improve with miles.
Old Dec 18, 2016 | 03:33 PM
dbirdhouse1's Avatar
dbirdhouse1
Default Agreed
...the first to second shift is balky until (and I would monitor it for the heck of it) the tranny temp inched off the stop,about 15 minutes of driving depending on other conditions.....otherwise it's quite nice.
I have added an MGW shift kit to my previous 2 C6's but I won't be doing that with this car....it is that good in stock form........
Old Dec 18, 2016 | 03:35 PM
dvilin's Avatar
dvilin
A little clunky when cold but once warmed up it is fine.
Old Dec 18, 2016 | 03:40 PM
Saint_Spinner's Avatar
Saint_Spinner
As others have stated, for some reason shifting from 1-2 sucks when transmission is still cold. I would often just skip to 3 until warmed up. All other gears are smooth (even when cold). Once warmed up, 1-2 will be just as smooth as others.
Old Dec 18, 2016 | 03:44 PM
brooklync5's Avatar
brooklync5
Old Dec 18, 2016 | 03:58 PM
spireland's Avatar
spireland
Thanks for the tip on warming it up, I figured it had to have been something like this. Thanks!
Old Dec 18, 2016 | 05:04 PM
Rowteree's Avatar
Rowteree
Put more mileage on the transmission. Around 8k, you shouldn't have any issues. Needs warm up from 1st to 2nd when new. Had that issue for a while
Old Dec 18, 2016 | 05:10 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Needs to warm up first. I have only 3000 miles on mine but after warming up the 1-2 shift is fine.
Old Dec 19, 2016 | 07:34 AM
bigblock427's Avatar
bigblock427
On mine, during warm weather or when the transmission is warmed up the 1-2 shifts smoothly. In cold weather and when the transmission is not warmed up, the 1-2 shift is very hard engage smoothly. During those times I do a 1-3 shift.
Old Dec 19, 2016 | 07:38 AM
Corgidog1's Avatar
Corgidog1
No problems for me with the 1 to 2 shift.
Old Dec 19, 2016 | 09:23 AM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Same here. I do shift into second right out of the driveway, but it's a little difficult in cold weather. I don't do the first to third thing others have mentioned. 7200 miles on a 2014 Z51.
Old Dec 19, 2016 | 09:24 AM
JoesC5's Avatar
JoesC5
Are you familiar with the Corvette's CAGS 1X4 shifting? You might have been trying to shift into 2nd when the CAGS was engaged and it was trying to lock you out of shifting into 2nd gear.
Old Dec 19, 2016 | 09:39 AM
rrsperry's Avatar
rrsperry
The MGW shifter will fix that 1-2 problem. (and yes, the CAGS delete thing is a must.)
I hate it when I read somebody says "that's the way it should have come from the factory!!", but in this case, I gotta say it's true. This shifter should have come from the factory. The only downside is you have to buy it. But if GM just did it, it wouldn't add much cost to the car overall, maybe $100. But it's so worth it...
If you go Blah, Blah, blah... my shifter is perfect, then you just don't know better, and haven't driven a car that has it. No matter what you're doing, it's just better. No, I don't work for them...
Old Dec 19, 2016 | 09:51 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
Mine has 10k on it. It does seem to get better over time, but I have 2 04 GTOs with the 6 speed manual which the C7 M7 trans design is based on, and they do the exact same thing in the cold. It will always be a little balky when the trans is cold and the weather is cold enough.
To C7 M7 question
Old Dec 19, 2016 | 10:03 AM
Larry/car's Avatar
Larry/car
My previous 2014 was smooth when up to operating temperature, although a little clunky when cold, but not bad. The new 2017 is really stiff (@70 miles) but is starting to limber up. Fifth gear is the worst, have not used sixth or seventh yet.
Old Dec 19, 2016 | 10:34 AM
bearphoto's Avatar
bearphoto
SoCal Events Coordinator
St. Jude Donor '12
I'm guessing the CAGS was blocking him. Easy/soft low speed shifts are usually blocked by the CAGS unless you put the skip shift part in. I have the same problem occasionally with my 6 spd manual Challenger.
Old Dec 19, 2016 | 10:50 AM
Zaphod B's Avatar
Zaphod B
You can feel the difference between a CAGS-induced skip shift and a cold tranny balky shift. Also, in the C7 you get a message on the DIC when CAGS blocks a 1-2 shift.
