FOB not detected
Any suggestions?
Thx
Make sure the fob is warm so as to not crack the plastic.
The OP's scenario sounds like a possible RF interference problem, or the car battery is starting to go south. Don't know if the OP put the fob in the slot on the steering column or not (and if so, did it work?).
Obviously I'm not sure what your scenario is but for me...when my car doesn't detect the fob as shown on dash I just take my fob out of my pocket which usually has my phone in the same pocket...the car starts right up.
Hope this helps.
My 14 battery went bad at 2 years 2 months.
Merry Christmas to you as well!
Recently had a problem with my main FOB that I had changed it's battery 1 1/2 years ago on my 3+ year old C7. At first it required hitting the open door button from time to time. Then one day I got a "FOB Not Detected" signal and had to put it in the column slot to start.
Took both FOB's apart and tested the batteries with a battery tester that puts a load on the battery to get an accurate reading. It has an analog scale reading Weak and Good. Both batteries read into the good area but just on the "G" in Good. Checked a new battery I had and it read to the 2nd "O" in Good. Put it in and all was fine. That was a month ago, all still fine.
Note, I also used a pencil eraser and cleaned the contacts when I put in the new battery-definitely worth doing.
PS: Never stranded, can always use the removalble key to open the hatch, pull the cable on the left wheel well to open the door and start the car by putting the FOB in the column slot.
http://forums.corvetteforum.com/c7-g...s-and-rke.html
http://www.ls2.com/boggs/c7/C7RKENot...dchecklist.pdf
Elmer
From pages 2-7, 2-8 of the 2015 owner's manual
Starting the Vehicle with a Low
Transmitter Battery
If the transmitter battery is weak or if
there is interference with the signal,
the DIC may display a NO REMOTE
DETECTED or NO REMOTE KEY
WAS DETECTED. PLACE KEY IN
TRANSMITTER POCKET, THEN
START YOUR VEHICLE. message
when you try to start the vehicle.
See Key and Lock Messages on
page 5-35.
To start the vehicle:
1. Place the transmitter in the
steering column transmitter
pocket with the chrome buttons
facing up and the base towards
the passenger side.
2. With the vehicle in P (Park),
N (Neutral) or, Neutral, press the
brake pedal and the ENGINE
START/STOP button.
Replace the transmitter battery
as soon as possible.
