Display issues
Old Dec 28, 2016 | 02:05 PM
augerdogger's Avatar
augerdogger
Default Display issues
I have a '16 C7.r that has an issue with the cockpit displays. The problem appears to be random but seems to occur more frequently when the humidity is high. Both the drivers and multi-media display get very bright, almost to the point of hurting your eyes, and then fade to black in about 15 seconds. The last time it happened the car was in the garage and after the displays went dark the driver's display had 2 lines of text about having to restart the display. The **** to adjust the display intensity does not work. I took the car back to the dealer because the warranty ends soon. The car was not happy since it had 15-50 Mobil 1 and tire pressures were 26 psig. Temperature was 17F with patches of snow and ice, an interesting drive.
Old Dec 28, 2016 | 02:19 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
I'd bring it back. I would use the warranty because you don't want to deal with that post warranty if possible.
