2017 GS driver side sun visor replacement help
Old Jan 2, 2017 | 11:15 AM
browcom's Avatar
browcom
Default 2017 GS driver side sun visor replacement help
Need help to remove the visor to replace with home link unit. Have seen instructions for older years but can someone help with instruction for a 2017? Thanks
Old Jan 2, 2017 | 11:37 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
I can't imagine the process would be different. Remove that little cover, unscrew it, pull it down, unplug it then replace. I don't know if GM did something weird to the connector though, so you'd have to verify the 2017 p/n before you buy one.
Old Jan 2, 2017 | 03:03 PM
browcom's Avatar
browcom
Dumb question but how do we remove the plastic cover?
Old Jan 2, 2017 | 03:15 PM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
It's just snapped into place. I have plastic trim tools which I recommend, but you can just use a screwdriver to get under a side and pry down. It pops off.
Old Jan 4, 2017 | 03:22 PM
browcom's Avatar
browcom
Many thanks, it really was just that simple Ron
Old Jan 4, 2017 | 03:32 PM
L1FRDOG's Avatar
L1FRDOG
May I ask why you are placing the home link unit on a new GS?
To 2017 GS driver side sun visor replacement help
