DSC Sport Magnetic Shock controller observations
#1441
Travel Stops are at the bottom of the Velocity tab in the new firmware. I tried using it (still am using it) to send the shocks to full stiff at a predefined travel amount to help with rubbing.
I don't know what the Trig field is and I think it may improve the experience with Travel Stops if I did.
I was thinking the Stop field was where you tell the system how far from zero the physical bump stop is. Zero is established when you zero the travel in the Settings tab. The Trig field would be where you enter what distance from zero you want the different shock stiffness to start. The current field is where you enter the current to establish the shock stiffness. The distance between Trig and Stop would then have the different shock stiffness. But I'm just guessing.
Does anyone know the total shock travel for a Z51?
#1442
I think you also need the latest Tuner software (I have 1.6.7) to see the Travel Stop section.
#1444
for what it is worth, I was just like many on here....big price tag, the biggest I would have ever spent. After reaching out to my local dealer to get the OEM update ...they are as lost as all the other dealers and was not offering the upgrade.....that was the last straw for me, grabbed one of these, put it on a card (no interest) so I can pay it down with no cash outlay. I just received it but have not installed as i am traveling but drooling to get going . At the end of the day i will sell or reinstall in my next one .....got to get me some of this !!
Gonzo (01-14-2018)
#1446
I have a couple questions. I plan on getting this controller shortly (waiting on my Z to get shipped). I assume that if you go this route the GM upgrade is no longer relevant?
Also I am not a computer guy at all, and while I find this conversation fascinating, most of it is way over my head.
My question is this, if I buy one in near future I assume it will come with the most up to date software version? Additionally is this just plug in and go? I don't want to do any adjusting myself, I know DSC is way smarter than me, so I don't want to mess with it all. I just want to reap the benefits of DSC's hard work !!
#1447
#1448
To add to the above post, any future DSC calibration updates/enhancements will be free unlike OEM.
Gonzo (01-16-2018)
#1449
I haven't been on the track since the beginning of Dec, and for that event and all last fall I was running the firmware that preceded the current version, and a pdts calibration file that Mike developed at VIR last year.
Yesterday I finally got around to updating to the latest firmware and pdts file for my 2016 Z06, and then zeroing the ride height.
After loading I checked and had the correct firmware version. I then checked the Tuner software version. On the DSC site, and when you download it, it is called "DSC 1.6.7 Tuner.exe", so I figured it's version 1.6.7.
However, every time I've opened it and checked the version by clicking on "Help" and then "About DSC Tuner..." it says it's version 1.6.0, as you can see below. It looks like something is wrong, but I have this downloaded on two different laptops and it's the same on both, so I don't think anything is the matter with the Tuner software I downloaded.
But, if anybody else can verify that's what your Tuner software says also I'd appreciate it!! TIA
#1450
^ BEZ06
I also re-downloaded the Tuning Software a few weeks ago thinking 1.6.7 was an updated Tuning Software.
And I can confirm mine also shows 1.6.0 after checking the version on my laptop.
But like you said, I think it's all good
#1451
I downloaded it recently also. When I checked properties I see two different results.
and then this......
#1453
Former Vendor
#1454
You can also see in post# 1451 that when you check the properties of the Tuner.exe application under the "General" tab it shows that the name of the application is "DSC 1.6.7 Tuner.exe", but when you go to the "Details" tab it shows "Product version 1.6.0.0".
So....I guess even though the "Product version" isn't the same as the actual name of the application (DSC 1.6.7 Tuner.exe), if we have that one with the 1.6.7 in the name of the app then we have the latest version.
Thanks DSC for a great product!!!
#1455
That version number in the help and in the file properties is set in the compiler at compile time (looks like Microsoft Visual Studio). Mike will need to have his developer change that field in the project properties and recompile to get them to match. The actual file name anyone can change.
Don't worry though, if you have the travel stops section then you have the latest software at the moment.
#1457
I have the Travel Stops, but they're not configured with any values in there. Here's the Tuner software showing the Velocity page with the Travel Stops at the bottom, and it's loaded with the latest file put out by Mike (12-18-17C7-Z06V3.pdts calibration file), but nothing in those Travel Stops fields.
What exactly can we do with the Travel Stop feature???
#1458
Received 2,379 Likes
Thanks - that's what I figured!!
BEZ06 (01-16-2018)
#1459
I guess it was Mike that mentioned "bump stops" in a previous post, so I guess that's what he was talking about - stop the movement of the damper with the Travel Stop feature.
Thanks for that clarification.
#1460
It is a great tool but we need more instructions on the use of each feature. I have downloaded the manual into a MS Word document and update my copy in the right hand margin (new column) whenever I learn a new trick or tip. I just don't have the time or location to go out and try the various features at different settings, my fear would be that I get it too out of balance and cause an accident. So the more info spread here the better.
We need explanations on the following:
The difference between Compression and Droop?
What is STOP? I assume this is the limit of travel for the shock and is set based on need?
What is TRIG? I assume this is the trigger or start point to start affecting the stiffness of the shock?
What is CURRENT (mA)? How is it used? I assume this is the amount of current that starts to affect the shock when the sensor is triggered?
Mike (DSC) and team, you have provided a great tool and we become your sales staff, especially after you provide each update or adjustment free of charge. Keep the info and updates coming, there is a lot of us watching and learning even if we don't post daily.
