10% Ethanol a problem?
The computer does not directly measure anything in the fuel itself. It does not know how much ethanol is in the fuel. What it measures is percent residual oxygen in the exhaust gas. It does that via the O2 sensors. If you’ve been running on pure gas and suddenly switch to E10, then because E10 contains less energy and needs less air to burn, then the O2 sensors sense that residual O2 in the exhaust gas is rising. It corrects for that by reducing air to fuel ratio. The actual variable it manipulates to reduce air to fuel is not cutting air. That would reduce power. It wants power to stay the same. So it increases fuel at constant air. That’s why miles per gallon drops. It’s pulsing more fuel, while flow of air and engine power stay the same. But since more fuel is being pulsed at constant air, then air to fuel ratio has dropped.
Maybe where you are getting off the track is in thinking air to fuel is the variable being directly controlled. That isn’t so. What is being controlled is percent residual oxygen in exhaust gas as measured by the O2 sensors. So if a fuel is used which has less energy per gallon (such as a fuel with ethanol or a fuel that has been blended for some reason to a lower than usual liquid density), then the closed loop system senses exhaust gas residual oxygen rising and squirts a bit more fuel at any given throttle butterfly position. When it does that, air to fuel ratio has dropped, but that’s not really the variable being controlled. It is just squirting more fuel so that it will use up all the air, and the residual oxygen in exhaust gas will stay at its very low set point.
When you are at wide open throttle, what function do the O2 sensors perform?
Bill
Suppose the default air to fuel is 14.7 for pure gas and you are running E10 which needs 14.1. During cruise, the O2 sensors have picked this up via the logic in my earlier posts, and the way the change actually appears inside the engine computer is a positive fuel trim, meaning that at any given operating point, the computer injects more fuel than the default table calls for. If the default air to fuel is 14.1 for E10 and you are running pure gas, the same thing happens in reverse, only the O2 sensors react in the opposite direction, and the engine computer is running on a negative fuel trim, injecting less fuel than the default table. So it doesn’t matter what the default air to fuel is. The fuel trim as driven by the O2 sensors brings it to the correct point for the fuel that the car is using.
Now “floor it”, and you go into power enrichment mode. This is built into the default tables. I don’t know exactly what the design numbers are, but suppose the default table is for pure gas, which would mean 14.7 air to fuel at cruise. In power enrichment, you want a richer mixture, so the default table may call for a richer, 12.7 air to fuel (again, I don’t know that exact number, I only know that it is richer). The O2 sensors don’t respond fast enough, so their input is ignored in power enrichment. But the fuel trim is not ignored, it is carried over from what it was during cruise. So in this example, suppose you are running E10. Your operation during cruise would have responded to the O2 sensors and picked up a positive fuel trim to shift air to fuel from the default table’s 14.7 down to 14.1. When you go into power enrichment by flooring it, that trim carries over, so instead of the computer going from 14.7 to 12.7 as it would on pure gas with zero fuel trim, it goes from 14.1 to 12.1, as influenced by the positive fuel trim which is carried over from cruise.
Overall, what the computer is doing is tracking another technical term that I haven’t gotten into, namely stoichiometry. I don‘t want to go into that whole discussion, as it gets lengthy. Other posts by both me and other people have done that, so you can search the term is you are curious. But after all is said and done, what stoichiometry means is that the engine computer uses the O2 sensors and resulting fuel trim to adjust things to have the right air to fuel for the fuel that is being used. Many other things besides ethanol can impact the proper air to fuel ratio. I mentioned one of them in an earlier post, namely, the liquid density of the fuel. That changes quite a bit during winter due to the butane that is added to boost vapor pressure to help cold starts in cold weather. Another thing that impacts the exact air to fuel ratio is the relative amounts of paraffins, naphthenes, olefins, and aromatics in any given batch of fuel. So what is really being targeted by the engine computer is not air to fuel ratio. It is getting the air to fuel ratio right, as influenced by stoichiometry, as measured by the O2 sensors, and as manipulated by the fuel trim.
In the last couple years many of the stations in the area now have "Hi test" none E gas available.
Contrary to what some people say crap ethanol gas makes a performance and mileage difference. It was quite noticeable in my 07 Z06 and my boat lost 3 MPH off the top end. Knowledgeable boat owners will tell you that it takes 15 HP for each MPH increase over 50, so do the math.
I do not know what the effect is with my 15 Vette as I only put none e gas in it!
I do not know with certainty whether boats have such engine management systems. Very few carburetors have active air to fuel ratio control, so if your boat’s engine is carbureted rather than fuel injected, it almost certainly doesn’t have such controls. Even if fuel injected, it may have only a default air to fuel table without the fuel trims driven by O2 sensors. If the engine does not have closed loop control with O2 sensors, then you will see a reduction in performance going from pure gas to E10. An engine without closed loop controls will run leaner and have less power on E10, so your observation of less speed/power on E10 would be perfectly reasonable. But as noted in the prior paragraph, it would not apply to cars, since all cars have all had such systems since the early 1990’s.
So you may be throwing some money away in your cars, but I'd keep the ethanol out of your Italian motorcycle.
Bill
Sure, some of them don't have ethanol fee gas, but the vast majority of the states do sell ethanol free regular and/or premium. Some have a few stations, like California or Maryland, and some have a lot of stations like Oklahoma. Locally(Springfield, MO), I can buy ethanol free 91 and 93 octane gas without any ethanol at 23 different locations within a ten miles radius of my home, a mix of them non Top Tier(11) and Top Tier(12).
One of the things tuners sometimes do is to alter the OEM A/F mixture tables in the ECM software, which is one method of deriving extra HP, but too lean can grenade the engine. That's one of the primary reasons one has to be very careful w/ an aftermarket tune. OEM programming generally errs toward the rich side to protect the engine.
I was under the impression that the base line was preprogrammed into the computer and then the O2 sensor referred to that preset number to determine if the mixture was either rich or lean. I was also under the impression that that preprogrammed baseline could be changed by the the factory in their factory tune, or changed by a tuner that went into the computer and changed that baseline number, or the computer could be tricked into a different baseline by installing an aftermarket air breather that enlarged the ID of the tubing where the MAF is located, thus changing the sampling ratio of the MAF and then the computer thinks the baseline has been changed and thus the car runs leaner vs using the stock air breather that matches the sampling ratio designed into the system by GM.
By changing the preprogrammed A/F mixture ratio in the computer, the lean or rich as detected by the O2 sensors can actually cause the car to run leaner or richer than what the factory set as a baseline.
That's why I said that GM changed the baseline number from what was used in the C6's to what is used in the C7. Jim Hall has a lot of knowledge about designing air breathers to trick the computer to cause the car to run leaner than what GM designed. In order to design his air breathers he needed to know what baseline A/FM was preprogramed into the computer by GM and Jim has stated that GM set their baseline A/FM based on E0 gasoline for the C6's and different baseline A/FM for E10 for the C7.
Of course some tuners remove the O2 sensor(generally when they install aftermarket headers), thus the computer adjusts the A/FM based on the preprogrammed baseline in the computer and info from the MAF. There is no feedback from the O2 sensors as to the amount of oxygen in the exhaust pipe, as they are not in the system.
I stated that there was slight change in performance when going back and forth between E0 and E10, and that's because GM installed different baseline A/FM into the computer in the C6 vs the C7.
I believe it's a proven fact that the LS(C6) and LT(C7) engines run on the rich side and by leaning out the A/FM the cars picks up horsepower.
At the risk of seeming redundant with earlier posts, suppose you have active O2 sensors and your default A/F map is set up for pure gas. If you then run E10, the O2 sensors will sense that there is more residual oxygen in exhaust gas than it expects (too lean), and regardless of where you are in the operating envelope, the computer will subtract about 0.6 A/F from the value in the default table. If the default map is set up for E10 and you run pure gas, the O2 sensors will sense rich, and will add about 0.6 A/F to the values in the table. So in the end, it doesn’t make any difference whether the default A/F table is for pure gas or E10. The O2 sensors will sense proper rich/lean, and will use the fuel trims to bring you back to the proper stoichiometric point in the map from either starting position.
Remember, it’s stoichiometry that you really care about, not A/F, and the relationship between A/F and stoichiometry depends on fuel composition. You’re stuck with using an A/F table since air and fuel are what the computer can manipulate, so the question is, how do I make that A/F table into a stoichiometry table. When you take an A/F table and then add in fuel trims as driven by O2 sensors, you then have a stoichiometry table which is what you really want. You would need different A/F tables for different fuel compositions. You only need a single stoichiometry table, regardless of fuel composition.
One way would be to disconnect the closed loop O2 sensor controls, which would cause you to run with whatever the default A/F mapping is. In that case, the default A/F mapping would obviously matter. You could either change the mapping in the computer, or you could indirectly vary the mapping by messing with the MAF sensor as you noted in post #55. But for the MAF trick to work, the O2 sensor circuit would have to be disabled, otherwise, fuel trims would bring you back to the original mapping. Trouble is, if you go this route, you lose the ability to have the computer adjust for different fuel composition. While ethanol is the single biggest variable in that area, even if you stick to only “pure gas”, ideal A/F can vary from about 14.5 to 14.9 depending on the exact composition of the batch of gas you happened to get. I’d also guess that this approach would set trouble codes that would not pass inspection in quite a few states.
If you leave the closed loop O2 sensor controls in place, then to change how rich/lean you run at any given power setting, you’d have to change the mapping in the computer of what residual O2 level it expected at any given power setting. I’m sure that could be done, and perhaps the reason we are disagreeing is that we are not using words that are clear to each other. What you describe as changing the A/F baseline may be what I describe as changing the residual O2 mapping. Another variant on that idea would be to change the degree of power enrichment built into the A/F mapping. Since you go off closed loop control when in power enrichment, then you could make yourself richer or leaner at wide open throttle without doing anything to the O2 sensors or residual O2 mapping. But none of the changes in this paragraph would result in any differences between pure gas and E10. The fuel trims generated by the O2 sensor circuit while in cruise would insure that the degree of richness would change equally for both pure gas and E10.
