Missing cupholder insert on my C7. Where to buy?
I am missing the cupholder insert on my C7. Does anyone know where I can buy this small part? see area below circled in blue for the item I am missing.
Or here, in the for sale and want to buy forum.
That's a problematic little piece, no matter how you look at it.
Or your local dealer. They should be able to get any all little parts for you.
Received 1,694 Likes
St. Jude Donor '15
It's expensive for what it is. If you didn't have it, I'd ask the dealer for it. Here you go:
http://www.cultragfactoryparts.com/c...name=separator
That's crazy!
That's crazy!
Received 19,300 Likes
'20-'21-'22-'23-'24
You might try one of the used parts vendors here on the forum also to see what price they may have.
I totally agree with owc6. That little piece sucks. It flops around and you can't count on it to hold your drink. I just did the Toyota Camry Cupholder mod and it works great. If you can dremel, this is what I recommend.
Here's mine (you can't see it, but I used a little velcro to make it extra secure):
Got the idea from this thread: https://www.corvetteforum.com/forums...lder-mods.html
Boiler_81 (02-17-2018)
52 damn dollars. That's a meal at a high end restaurant lol.
St. Jude Donor '09
Its "only" $44 plus tax and shipping at another supplier. Still overpriced for a dab of molded plastic. This should be a $10-20 part.
I think GM prices stuff higher the more likely they think it will get lost or damaged and need replacing.
Try a scrap yard like Pick-a-Part
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
When you get one modify as I have done or the insert is not secure and holder is shallow.
First remove ~3/32 inch thick rubber cover from bottom of recess. It just pulls up.
Then use UV activated adhesive to make a fillet from the Insert to the bottom.
I added some felt pads on the sides to hold a water bottle snug. It holds in 1 "g" turns and 1++ "g" stops.
C7 Cup Holder Divider
What is the name of the other supplier? Thanks
I think I have one from my stingray I traded in. I'll look.
