E-brake coming on automatically
Old Jan 15, 2017 | 01:37 AM
R8Z51's Avatar
R8Z51
Default E-brake coming on automatically
Hi folks,
I've noticed my electronic parking brake automatically comes on when I go to start the car up. I have never turned it on manually. Is this some sort of a safety feature? It's done it 3-4 times now.
Popular Reply
Jan 15, 2017, 03:14 AM
WelderGuy's Avatar
WelderGuy
It comes on automatically every so often to check the operation of the system.
Old Jan 15, 2017 | 03:14 AM
WelderGuy's Avatar
WelderGuy
Old Jan 15, 2017 | 08:53 AM
golden2husky's Avatar
golden2husky
Yep, mechanical atrophy is as bad as physical atrophy for a human. If the system went unused for a few years it might no longer engage, or worse, disengage. Use the parking brake on all of your cars at least periodically.
Old Jan 15, 2017 | 09:43 AM
Larry/car's Avatar
Larry/car
Good find. The parking brake system is so simple I just breezed over it and missed the auto on part. I'm bad!
Old Jan 15, 2017 | 02:57 PM
R8Z51's Avatar
R8Z51
Good to know. Thanks guys!
Old Jan 15, 2017 | 03:02 PM
defaria's Avatar
defaria
It's never come on automatically for me. I have an M7, if that matters.
Old Jan 15, 2017 | 03:29 PM
R8Z51's Avatar
R8Z51
The weathers below freezing here so it might only do it at certain temperatures to prevent it from binding up.
Old Jan 15, 2017 | 04:27 PM
Flame Red's Avatar
Flame Red
Inquiring minds gots to know...
I have never seen it come on by itself and I rarely use the parking brake. But I live in the Florida Inferno, so perhaps it does have something to do with temperature?
So I checked the Helms service manuals and under the Parking Brake System Description, there is no mention of it having the capability to apply itself - except as part of the M7 Hill Assist feature. Is the OP an M7 and perhaps it is somehow sensing it is parked on an incline and using Hill Assist?
Old Jan 15, 2017 | 04:37 PM
Smart Line's Avatar
Smart Line
Mine turns it self off i like that feature.
M7
Old Jan 15, 2017 | 04:39 PM
R8Z51's Avatar
R8Z51
My car is a 2014 with the A6 transmission.
Old Jan 15, 2017 | 04:51 PM
joemessman's Avatar
joemessman
I have noticed on mine that periodically, not often, when I got to start the car it displays something indicating the parking brake is on. I didn't ever remember engaging it. I didn't realize it did it automatically once in a while. Learn something new about the car everyday.
Old Jan 15, 2017 | 04:55 PM
DAFFYDRUNK's Avatar
DAFFYDRUNK
Mine has never come on automatically but I use it all the time. It must only do this if its not used.
Old Jan 15, 2017 | 05:27 PM
joemessman's Avatar
joemessman
I'll bet that's it. I never have to use mine. I never seem to park on any hills.
Old Jan 15, 2017 | 05:28 PM
R8Z51's Avatar
R8Z51
Is it necessary to use the parking brake when parking on an incline or decline?
Old Jan 15, 2017 | 07:10 PM
DAFFYDRUNK's Avatar
DAFFYDRUNK
Probably not, but I use it in automatic cars if the hill is steep. Apply it before putting the car in park and releasing the brake, then when leaving, put the car into gear before releasing the ebrake to make getting out of park a little easier.
On manual trans cars, I use the ebrake all the time because I once had my old 96 TA pop out of gear and roll into the street where it magically hit a soft mattress a neighbor left out for trash pickup that morning. If the mattress wasn't there they would've been fishing the car out of a creek.
Old Jan 15, 2017 | 07:50 PM
owc6's Avatar
owc6
If you park an automatic on an aggressive incline w/o the parking brake, it it's possible to torque lock the transmission.
When this happens there is so much stress on the locking pawl that you can not get the car out of park, which requires the car to be pushed uphill to release the shifter. To avoid this, when parking on a hill, do as daffy says and apply the parking brake Before shifting to park.
Old Jan 15, 2017 | 11:37 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
On a side note, on the automatic transmissions I've had apart, I frankly am skeptical of the parking pawl mechanism. To think that this usually rather small part actually holds the entire car in place, including inclines, seems insufficient. Yes, I know the engineers have figured it out, and no I haven't seen the specific parts in the Vette's A6 or A8 yet, but I've been setting the parking brake in every car I drive, manual or auto, since way before I started using seatbelts lol
Old Jan 15, 2017 | 11:47 PM
Foosh's Avatar
Foosh
The parking brake has always been engaged on every car I've driven for decades. It's a simple precaution, a habit for me like the shoulder harness, and it saves wear and tear on the transmission, manual or automatic.
And yes, as OWC says, engage the parking brake before putting a vehicle in Park or releasing the clutch on a manual.
Old Jan 26, 2023 | 11:10 AM
semperfi1946's Avatar
semperfi1946
My 2021 Z51 comes on automatically sometimes. I was torquing wheel lug nuts to specs and the system activated about 2 minutes after I got out of the car. I also get some squeaking while backing out of garage and I need to tap brakes a few times to get rid of noise-really embarrassing with a car with only 1,900 miles on it.
To E-brake coming on automatically
