Rough idle
Old Jan 31, 2017 | 11:36 PM
RaceMic's Avatar
RaceMic
Default Rough idle
I'm noticing a bit of a fluctuation at idle in my new GS (less than 500 miles) Kind of like a cam lope, but a little rougher. Should I be concerned?
Old Feb 1, 2017 | 12:03 AM
Foosh's Avatar
Foosh
No, normal.
Old Feb 1, 2017 | 09:17 AM
dvilin's Avatar
dvilin
Old Feb 1, 2017 | 09:37 AM
Hopper12's Avatar
Hopper12
100% normal
Old Feb 1, 2017 | 09:44 AM
brooklync5's Avatar
brooklync5
One of the few things I dislike about my c7 is it's rough idle. It is normal however so we just have to live with it.
Old Feb 1, 2017 | 12:10 PM
Grand Slam's Avatar
Grand Slam
When I picked up my new GS last Friday my dealer warned me not to be worried about it unless the RPM varied a lot.
Old Feb 1, 2017 | 01:23 PM
RaceMic's Avatar
RaceMic
Glad I asked. That sets me at ease. Thanks.
Old Feb 1, 2017 | 03:20 PM
C7Joy's Avatar
C7Joy
To my ear, a little idle roughness actually sounds tough. Performance cars seldom tick evenly like a clock.
Old Feb 1, 2017 | 05:54 PM
BELVIN20's Avatar
BELVIN20
460 HP is not likely to have a perfect smooth idle, I am amazed the cars today with the power they have is amazing they idle as smooth as they do. I can tell from your comments you never had a high horsepower car from the 70's. They would idle at maybe 1000 rpms & shake the ground they were sitting. It is normal for it to have a little bump at idle. You need to sit a new Z06, they even have more of a idle bump.
Old Feb 1, 2017 | 05:59 PM
cbach5885's Avatar
cbach5885
Even at 460 HP they would idle smooth if not programmed otherwise. It's a design feature to give the illusion that it has a "lope" like a radical cam creates. Apparently GM decided that's what Corvette drivers like, but I could live without it as it always seems something is wrong to me!
Old Feb 1, 2017 | 07:29 PM
hangman's Avatar
hangman
I wish it was a bit rougher, as I like that...
Old Feb 1, 2017 | 07:52 PM
Foosh's Avatar
Foosh
It's a very high-compression engine by street car standards. It's pretty amazing to get 460HP out of a little over 6 liters naturally-aspirated.
Old Feb 1, 2017 | 08:20 PM
RaceMic's Avatar
RaceMic
Actually, I've owned and restored a 1964 Chevelle SS, a 1966 Buick GS vert, a 1966 Buick GS hard top, and a 1972 Mercedes 300SEL 6.3. All ran smoother at idle than my 2017 GS. My 1996 C4 and 2007 C6 both feel smoother at idle than my 2017 C7 GS. A car this sophisticated and expensive I expected to be a bit smoother at idle. As a design feature, I get it, but it just kinda feels to me like it has a miss. I'm glad it's not.
Old Feb 2, 2017 | 01:53 AM
WelderGuy's Avatar
WelderGuy
My 306HP 3.5L V6 engine (87HP/L compared to the C7 at only 74HP/L) idles as smoothly as my Caiso wrist watch. I'm sure the variable valve timing helps, though.
Old Feb 2, 2017 | 02:01 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Comes with 460 hp and keeping pollution low at idle! I'm surprised it's as good as it is! A Duntov cam in a 300 hp '50's/'60's small block Chevy was much loopier!
Old Jan 1, 2018 | 12:06 PM
jimmbbo's Avatar
jimmbbo
The small block Chevy V8s with hydraulic lifters were quite docile at idle, and you likely recall that the more radical hotrodders back in the day installed a Duntov "30-30" cam (for the .030 inch valve lash on both intake and exhaust) with solid lifters that would barely idle below 1000 RPM, loped like a pony and sounded like a threshing machine...
Old Jan 1, 2018 | 12:48 PM
NSC5's Avatar
NSC5
In general most direct injected engines seem to have a little rougher idle than their port injected counterparts. Lexus uses combined port plus direct injection in some configurations and this provides a smooth idle for them. I haven't looked that closely at the new ZR-1 powerplant to see if its port injection is active at low RPM/low load conditions or if port injection is only used at higher load to supply the needed fuel but I expect GM will be using this combination on future luxury engines before the internal combustion engine comes to the end of the road.
The smoothest idling vehicle I currently own is a GMC Sierra pickup with a 6.6L turbo diesel and its idle is much smoother than the 3.6L DI in my Cadillac ATS and the LT-4 in my Z06.
To Rough idle
Old Jan 1, 2018 | 01:17 PM
Billy346's Avatar
Billy346
I like a little lope in the idle of an American sports / muscle car. In my opinion, it's a distinctly American sound in the same way that a turbo whistle is to a Japanese car or a flat plane crank scream in an Italian car. It tells the driver and people nearby that this car has some power!
Old Jan 1, 2018 | 01:29 PM
DALE#3's Avatar
DALE#3
With a factory warranty
Old Jan 1, 2018 | 01:33 PM
John Micheal Henry's Avatar
John Micheal Henry
No that should put a smile on your face..
