Playlists on flash drive
1. What Playlist file type are you using? .M3U is the recommended format.
2. How are you creating the Playlists on your flash drive? If you're simply copying playlist files from your PC hard drive to the flash drive, that likely will not work.
3. Windows Media Player can work, but I stopped using it several versions ago, as I found it inconsistent and unreliable for this purpose. I continue to live by the old program WinAmp for this task. While WinAmp is no longer updated, it still works perfectly on my Win10 PC, especially for syncing my Music Collection to two 128GB drives (one for my C7 and the other for my Electric Caddy ELR).
4. I have zero issues syncing collection of 14,500+ songs, along with about 10 different playlists, each consisting of anywhere between 50 to 500+ tracks.
I'd be happy to try to assist you further, but you'll need to provide more info on the specific procedure you're working through and the file types you're using for both the music files and the playlists.
https://www.corvetteforum.com/forums...post1592043733
I posted a PDF in there about how to do it from iTunes.
The most important part as others have touched on is .M3U files, and then within those files that the "path" is correct. If the "path" is wrong then the ,M3U can't find the MP3 files and therefore the playlist is "empty" and doesn't show up on the MyLink system.
Here is an example of the beginning of one of my playlists
#Playlist: 'Beatles (All Mix)' exported by iTunesExport (Flex) http://www.ericdaugherty.com/dev/itunesexport/
..\The Beatles\Please Please Me (Mono)\01 I Saw Her Standing There.mp3
..\The Beatles\Please Please Me (Mono)\02 Misery.mp3
..\The Beatles\Please Please Me (Mono)\03 Anna (Go To Him).mp3
..\The Beatles\Please Please Me (Mono)\04 Chains.mp3
..\The Beatles\Please Please Me (Mono)\05 Boys.mp3
..\The Beatles\Please Please Me (Mono)\06 Ask Me Why.mp3
the ..\ is because I keep my M3U files in a playlist folder. If you keep them in the "root" folder it would just be \ (no ..)
As you can also tell I have my files organized by Artist then Album.
