Removing the right side dash pad.
Old 02-14-2017, 06:40 PM
Dave Kitch
Dave Kitch's Avatar
Default Removing the right side dash pad.
I have the glove box out and 3 of the 5 screws out. Must you remove the aluminum plate inside the glovebox to access the 2 center screws?
Dave K.
Old 02-14-2017, 07:13 PM
Jmcdude
Support Corvetteforum!
Jmcdude's Avatar
May find what you're looking for in this how to sticky.
https://www.corvetteforum.com/forums...nger-dash.html
Old 02-15-2017, 10:35 AM
Dave Kitch
Dave Kitch's Avatar
Thanks but already used this. Not enough detail showing where center screws holding dash pad are located.
Old 02-18-2017, 10:16 AM
Dave Kitch
Dave Kitch's Avatar
I removed the dash pad. The problem was that GM during assembly did not align the aluminum glove box frame to the point that I could get access to the upper screws. Drilled access holes through the frame which gave me access to the two screws.
To Removing the right side dash pad.
Quick Reply: Removing the right side dash pad.
