Rough idle?
Old Feb 18, 2017 | 05:41 PM
JenFZ09's Avatar
JenFZ09
Default Rough idle?
Does your vette have a rough idle? I have a 2016 with just under 2k miles and have noticed this almost from the start. It does have a large engine, so it could go with the territory. Thanks!
Old Feb 18, 2017 | 05:44 PM
Larry/car's Avatar
Larry/car
Normal
Old Feb 18, 2017 | 05:47 PM
767guy's Avatar
767guy
Originally Posted by Larry/car
Normal
Yup, Normal
Old Feb 18, 2017 | 06:11 PM
L8ter's Avatar
L8ter
Normal
Originally Posted by 767guy
Yup, Normal
Old Feb 18, 2017 | 07:31 PM
Red C8 of Jax's Avatar
Red C8 of Jax
460 horses rumble!! If you have a Z06, 650 really rumble!!!!!!!
Old Feb 18, 2017 | 08:19 PM
JenFZ09's Avatar
JenFZ09
Thanks for the replies. Our Challenger also has a large V8 and doesn't idle like this. My Camaro didn't either, so I was wondering if there was an issue.
We have a stingray with the exhaust.
Old Feb 19, 2017 | 07:26 AM
mksz51's Avatar
mksz51
It's not just the size of the engine - it's the tune, cam, etc. that is in the engine. Likely, it's mostly related to the camshaft. You could have the same degree of roughness with a small engine as a large if the tune were such to give a similar power to displacement ratio.
Old Feb 19, 2017 | 09:51 AM
felkebg's Avatar
felkebg
We all paid extra for the rough idle...... burble on C7!
Old Feb 19, 2017 | 10:58 AM
JC 2004's Avatar
JC 2004
There is a certain amount of rough idle designed in as an homage to the rough idling muscle of years ago. With that being said rough idle is subjective. I see you ride and have other v8's so you are familiar enough with engines to notice something amiss. If the motor is smooth other than at idle the chances are good that's it's normal operation. Certainly bad gas, sitting for a while, summer blend vs winter fuel, even a loss of power could cause short term issues. I only mention this since you have multiple transportation options.
I would hope a rough idle outside of parameters would throw a light, but as long as your oil level is good it would be GM's issue.
Old Feb 24, 2017 | 07:53 PM
Dr Man's Avatar
Dr Man
LOL, Amen
Old Feb 24, 2017 | 09:12 PM
BAblackvette's Avatar
BAblackvette
Mine idles rough, RPM even dips occasionally at idle. Valvetrain noise, etc. All comes with the territory
Old Feb 25, 2017 | 02:13 PM
Rebel Yell's Avatar
Rebel Yell
To give you example of what some are saying about the difference in engine set-ups. My wife has a '13 Mustang GT with the 5.0L that has a bit of a rough idle, and I have a '13 F-150 with the 5.0L that idles smoothly. Same size engine, but different applications.
BTW, my '16 Vert idles rough also. You're good to go.
Old Mar 5, 2017 | 03:04 PM
MallettHammer's Avatar
MallettHammer
8th Gear
Consensus in the forum (not just this thread) is that it's normal, even if it shakes the cabin a bit. I find this surprising but a relief, because my C7 Z51 has what seems to be an exceptionally rough idle. A salesman agreed with me when we sat in my car, then another C7 on the lot. Once or twice a second, it jostles the cabin. My dad's C6 doesn't do that. It was worried enough that I was planning to take the car in for diagnostics this month. Guess I'll live with it....
Last edited by MallettHammer; Mar 5, 2017 at 04:02 PM. Reason: Learned more by searching forum...
Old Mar 7, 2017 | 11:04 AM
TwoVettes6916's Avatar
TwoVettes6916
I have just over 500 miles on my 2016 C7. I wondered about this at first as well. But considering the idle rpm and the size of the pistons, etc., and not knowing all the specifics about the cam, I have come to the conclusion that it is normal with this engine.
Plus, as soon as I press the gas pedal to accelerate, there is never any hesitation, just a strong, smooth increase in speed.
Old Mar 7, 2017 | 12:04 PM
fugly1's Avatar
fugly1
Not a bug; a feature.
Old Feb 7, 2020 | 05:26 PM
Steve Kistler's Avatar
Steve Kistler
Better I hop
Old Feb 7, 2020 | 05:49 PM
RWDonly's Avatar
RWDonly
Originally Posted by Steve Kistler
Better I hop
Ummm what? IHOP? Are you craving pancakes?
To Rough idle?
Old Feb 7, 2020 | 06:47 PM
Maxpowers's Avatar
Maxpowers
If mine didn't have the idle rumble, then something is wrong. Enjoy.
Old Feb 7, 2020 | 08:09 PM
ftlaud1's Avatar
ftlaud1
May I suggest driving the car to get it broke in after 3 years , lol 500-2000 miles in 3-4 years is not using the car at all.
I have 3100 miles after 9 months and I feel guilty?
Old Feb 7, 2020 | 11:44 PM
Avanti's Avatar
Avanti
Given no more cam than they have, yes, they are otherwise surprisingly rough. Btw, size isn't the issue.
