Nav Map
Old Feb 20, 2017 | 02:17 PM
jforce's Avatar
jforce
Default Nav Map
Suddenly on my 16 Coupe my Map screen has gone blank. Everything else is fine. Am I missing something or do I have to go back to the dealer?
Old Feb 21, 2017 | 10:24 AM
Boiler_81's Avatar
Boiler_81
Dealer time
Old Feb 21, 2017 | 06:13 PM
Larry/car's Avatar
Larry/car
Originally Posted by Boiler_81
Dealer time
Try disconnecting the battery for about thirty minutes. That should set everything back to factory defaults. When you reconnect the battery wait about five minutes for everything to power back up before trying to start the engine (it will not start until everything comes on line).
Old Feb 21, 2017 | 08:05 PM
blue max's Avatar
blue max
Default Blank screen
I know this will sound dumb. I just had a friend have the same issue. I suggested they go to the light control on the left side of the steering wheel. They had inadvertinately turned it down while doing something in the same area.
Check that out first its the easiest
just sayin
To Nav Map
