2nd gear
Old Feb 22, 2017 | 07:09 AM
alon berger's Avatar
alon berger
Default 2nd gear
when i shift from 1 to 2 in low rev it is not smoth
i feel like screech.
if i pool the 1 for hige rev it go for 2 smooth
anyone feel the same?
Old Feb 22, 2017 | 07:24 AM
767guy's Avatar
767guy
There is a huge amount of material on this issue.
Go to the search box and look for " harsh 1-2 shift" and you will find enough reading material to keep you busy for weeks....
Old Feb 22, 2017 | 08:08 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
I wouldn't worry much. It's normal. I have 3 cars with similar transmissions and they all do the same thing. A bit clunky going into 2nd, especially when cold. Not so noticable when warmed up.
Old Feb 22, 2017 | 12:22 PM
1500cc's Avatar
1500cc
Yep, every Tremec I've driven has been the same. I usually go from 1 to 3 most of the time anyhow, unless I'm bootin' it. It generally makes for a smoother shift (aside from no grinding), because unless you really force the 1-2, they're so close together and by the time you let out the clutch, the RPMs have dropped too far and the car has to speed the engine back up, making it a bit jerky.
Old Feb 22, 2017 | 03:23 PM
dvilin's Avatar
dvilin
Old Feb 22, 2017 | 03:54 PM
fugly1's Avatar
fugly1
Borat, is that you?
To 2nd gear
