Replace battery question
Old Feb 25, 2017 | 04:09 PM
See 8's Avatar
See 8
Default Replace battery question
When replacing the battery is there anything that can be done to not mess up the computer and memory loss?
Old Feb 25, 2017 | 04:27 PM
owc6's Avatar
owc6
Don't forget to re-index the windows when done.
Old Feb 25, 2017 | 04:36 PM
See 8's Avatar
See 8
I'm trying to avoid all that if there is anything I can do to keep 12v in the system.
Old Feb 25, 2017 | 05:15 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
I had zero problems when I changed mine this summer. More difficult swap than my C6 and with it I had to index the widows. No big deal but with the C7 was disconnected for over an hour and no reprogramming anything-even the windows indexed fine.
I did nothing special. However if you'd like the carpet back not to crack or worse rip at the plastic wheel wheel cover-pope it off.
There are also tricks to getting the large power board on the positive terminal off. This is a picture/text PDF of my install of a AGM battery this past summer: http://netwelding.com/Battery_Issues.pdf
The first 6 pages are the install, there are others after about voltages and issues I had with the OEM battery.
Old Feb 25, 2017 | 11:00 PM
See 8's Avatar
See 8
Many thanks Jerry!!!!!!
Old Feb 26, 2017 | 01:09 PM
Rebel Yell's Avatar
Rebel Yell
I've never had any problems my friend. But, you will have to re-index the windows as Lisa (owc6) advised. There's no way around that, but it's EZPZ.
Old Feb 26, 2017 | 04:11 PM
JerryU's Avatar
JerryU
I was surprised I did not have to when the battery was out for an hour when changing. Go figure. But as you say it's an easy proceedure outlined in the Owner's Manual.
To Replace battery question
