Factory settings
Will "Return to factory settings" do it?
In addition if you have the visor garage door opener, holding down the 1 and 3 buttons simultaneously erases the programming to your garage doors.
You can try "return to factory" first, but that may not be linked to nav and phone, and it won't be linked to the garage door opener.
Return to Factory Settings
Touching Continue restores all factory settings.
Select Return to Factory Settings and the following list may display:
. Restore Vehicle Settings:
Restores factory vehicle personalization settings. Touch Restore Vehicle Settings. Touch Cancel or Continue. If Continue is pressed, a confirmation pop-up will appear indicating the vehicle settings have been restored.
. Clear All Private Data: Clears all private information. Touch Clear
All Private Data. Touch Cancel or Continue. If Continue is touched, a confirmation pop-up will appear indicating all private data has been cleared from the system.
. Restore Radio Settings:
Restores factory radio settings.
Touch Restore Radio Settings.
If Continue is touched, a confirmation pop-up will appear indicating the radio settings have been restored.
Hope this helps. Just had to do it on the wife's CR-V.
At least that is how it worked on the C6
Replaced my battery this past summer and was down for one hour. Was surprised I didn't even have to index the windows. I recall with my C6, had to do that with the drivers side window but the passenger window was fine. Go figure.I also thought I would have to reset my radio, that pays the 600+ songs on an SD card in shuffle mode when I start the car. It started playing as well!
