Dead battery & hatch won't manually open
Plus, I would probably scratch the heck out of the interior panels trying to get a hold of that latch. I still have two things to try today, hopefully one of them works.Off to buy a new battery, and see if applying power at the starter gets me in.
If you have OnSatr, and they can get you in, you're golden. Good luck.
I was able to apply power to the starter cable (at the starter) through the use of jumper cables from another vehicle, and a small cable I fabricated that could easily clamp on to the starter wire bolt, and after about 15 seconds the car came alive, and I was able to pop the hatch.The battery was down to 1.9 volts, so it is likely that I have done this battery in, and will go get a replacement now. Even throwing a fast charger on it to shock it back to life seems like it isn't responding well, I am guessing it has a dead cell or two.
Takeaways for me:
1) Don't forget to either remove/turn-off the Range AFM module or put the car on a charger before leaving for extended time (DUH!).
2) If you ever need to use the key to pop the hatch on a 2016 or newer Corvette, don't push it all the way back closed, until you have resolved the power issue.
3) Quickjacks are AWESOME! The way my car was parked in the garage, would have made it really difficult to jack up enough to get to the starter with normal floor jacks. Those things made light work of it.
Also be careful while trying to charge this deeply discharged battery as a sustained high charging rate is perfect for creating hydrogen gas in much higher quantity than happens in a normal charging cycle. Use a setting on your charger which does not allow a lengthy charge at high current or things may get a little too exciting.
Sounds like the OP has a mod that draws power 24/7. Oops.
A normally charged 12 volt battery has around 2.1 volts PER CELL (6 cells making up the battery). Once discharged to 1.9 volts total that battery is well past any reasonable deep discharge. 10 volts under load is considered to be at the extreme end of safe discharge and to measure 1.9 volts presumably under a very light load is off the low end of the scale.
Left the house for a week and forgot to put the Corvette on a battery tender
So once I got back and it was dead
[B]
QUOTE]
As some other members have mentioned, there might be something else that you need to investigate if the battery goes dead after sitting for a week.
My C7 sits for a month or more during the winter, and always starts right up when I finally want to get her out for a drive.
Good luck.
[QUOTE=TwoVettes6916;1594245200]
[B]
QUOTE]
Good luck.
