2014 Stingray option codes
Old Mar 7, 2017 | 11:32 PM
f1reb1rd's Avatar
f1reb1rd
Default 2014 Stingray option codes
Just purchased 2014 stingray. Yes and thanks you as well. But what i want to verify are were the codes are located that tell you what options were on the specific vehicle?
Old Mar 7, 2017 | 11:51 PM
Zymurgy's Avatar
Zymurgy
Moderator
The RPO label is near the battery cover under the carpet in the back cargo area on the passenger side. Be very careful trying to pull back the carpet. It will tear where it goes under the cargo side liner.
Old Mar 8, 2017 | 03:28 PM
Bob Beroza's Avatar
Bob Beroza
You can also purchase the window sticker specifically for YOUR car's Vin Number from the Corvette Museum. That way you have all the codes and you get a great piece of memorabilia.
Old Mar 8, 2017 | 04:50 PM
Zymurgy's Avatar
Zymurgy
Moderator
Window Sticker does not come close to listing all the RPO codes on a vehicle.
Old Mar 8, 2017 | 05:08 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
The carpet can rip or cause the backing to break when accessing the battery, etc.
I find if you remove the lower clips on the plastic wheel well cover on the passenger side and pull it out a few inches before sliding the carpet out, it avoids the problem. Posters have said a ripped carpet also occurred at a dealer.
No need to remove the upper fasteners, just pull it off the bottom clip. Can be done with your fingers. Snaps back on with the side of a closed fist. FWIW
Old Mar 9, 2017 | 05:22 PM
shakinrock's Avatar
shakinrock
What about all the RPO codes that do not seem to show up on lists? Such as BGR, B4H, EFR, R9Z, VRM, VRN, etc
I have about 40 codes on my Service Parts Identification sticker that do not show up on any RPO list I could find.
To 2014 Stingray option codes
