Problem with key fobs
Old Mar 15, 2017 | 08:39 PM
SugarGrl's Avatar
SugarGrl
Default Problem with key fobs
Okay guys I need your expertise. Got a new 2016 Vette with 1 key fob. Bought another one from the dealer along with key. Followed the instructions in the manual to the letter and now the only thing that works on both fobs are the remote start, the doors open and lock. The car can't be put in gear or backed out of garage. 1. How the heck can it be towed? And any ideas on the fob issue?
Old Mar 15, 2017 | 09:15 PM
Kent1999's Avatar
Kent1999
If the car starts and runs, it is not a fob issue. Once the car is started, you can throw the fob out the window and drive cross-country -- the car doesn't need it to run or operate in any way.
Also, the fobs are not keyed to certain functions. Either a fob is matched to your car or it isn't. The ONLY functions that depend on the number of the fob are the memory features (keyed to fobs #1 and #2), if your car is so equipped. There is no way to 'pair' the fob so that you can start the car, but not put it in gear.
Is the brake switch working? I know for automatics, you cannot put the car in gear without your foot on the brake. If the little switch on the brake pedal is malfunctioning, the car won't know you have your foot on the brake, and will prevent you from leaving "park".
Old Mar 15, 2017 | 09:36 PM
supervett455's Avatar
supervett455
i had the same problem you had, search in this forum or google it about corvette key program, there is a detailed instructions to fix your problem, don't tiw your car just yet, easy solutions for this i went through all this, but couldn't find the link now......will post uf I found it
Old Mar 15, 2017 | 09:52 PM
supervett455
here you go, see link below, read carefully and use Long Version for C7, PM me if you have problems
https://www.corvetteforum.com/forums/c7-general-discussion/3414464-everything-you-wanted-to-know-about-your-fob-s-and-rke.html
Old Mar 15, 2017 | 11:26 PM
Zymurgy's Avatar
Zymurgy
Moderator
Here's a working link version of what supervette455 posted: Everything you wanted to know about your FOB's and RKE
Old Mar 16, 2017 | 07:36 AM
SugarGrl's Avatar
SugarGrl
Got the fobs to work! I missed the step of putting the key back in the fob before sticking it back in the steering column. Duh! Thanks for your help boys!! I'll post a pic of my new pretty soon!
To Problem with key fobs
