OnStar diagnostic question
Old Mar 24, 2017 | 11:13 AM
Kelsvet's Avatar
Kelsvet
Default OnStar diagnostic question
Hey friends!
On Tuesday I drove the Vette to take my daughter to piano lessons. While driving I accidentally changed the menu and made it to my tire pressure which read 31 in each tire.
Fast forward to last night when I received my OnStar diagnostic report. It told me that I had 27 PSI in each tire and they all need air. I haven't gone out to check, but is this normal that the OnStar reads differently than the car?
Thanks in advance!
Old Mar 24, 2017 | 11:23 AM
joemessman's Avatar
joemessman
When you looked at the DIC and saw 31 in your tires they were probably heated up somewhat from driving. When OnStar ran the diagnostics your car was probably not driven for a while and they were cold.
Old Mar 24, 2017 | 11:54 AM
owc6's Avatar
owc6
but you still need air. 27 is too low. What does a hand-held gauge say?
Old Mar 24, 2017 | 12:22 PM
dvilin's Avatar
dvilin
30 psi cold, you should check as the aforementioned pointed out the on star reads when cold your reading was after tires were heated up from driving.
Old Mar 24, 2017 | 07:25 PM
Maxpowers's Avatar
Maxpowers
Are these the OEM sensors? My winter wheels have aftermarket sensors. If I don't drive within 24 hours they go into sleep mode. When I start the car they show 26psi until I drive for a few seconds. My OEMs don't do that.
Old Mar 24, 2017 | 07:45 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
I've found that the Onstar web page shows the monthly report that is issued, so it's not live data. But the app on my phone when you refresh it is live from what I recall.
Old Mar 24, 2017 | 10:07 PM
owc6's Avatar
owc6
The data on the phone app is taken from sometime when the car was last run (during the last ignition cycle).
The app says so, so I'm assuming that it is from the moment the car was shut down, and every time i've tracked the data, it appears that this is so. Miles, range, OLM, etc seem to always line up. Obviously PSI won't, because the tires cool down before next ignition cycle.
To OnStar diagnostic question
