FOB batteries
Old Mar 31, 2017 | 10:06 AM
C7Joy's Avatar
C7Joy
Default FOB batteries
I finally uncovered my car, ready to put it into service for another new year of fun. With my fob in my pocket I could not open the driver's door without hitting the unlock button. When I jumped in the car the instrument screen did not illuminate the way I am used to seeing it. I hit the start button and I got the Fob not found message. Ah hah! Battery time.
Eager to go for a ride I grabbed my spare fob. The instrument screen still illuminated incompletely and again, the car would not start. I guess that makes sense since the fob is electronically active, even though unused. I could have placed the fob in the steering column pocket but decided to put new batteries in the fobs. Fortunately I had a new pack of 2032 batteries.
Batteries replaced, everything back to normal! The point of this post is that 3 years seems to be the battery life in fob service. (I took delivery of my 2014 car 3/8/14). Suggestion: If your car has been in service 2 years or more, or the batteries are over 2 years old, it might be time for new batteries.
Old Mar 31, 2017 | 10:13 AM
Rooster OG's Avatar
Rooster OG
St. Jude Donor '15
Thanks for the heads up! What kind of batteries does it take?
Old Mar 31, 2017 | 10:18 AM
C7Joy's Avatar
C7Joy
CR2032 disc type batteries. Available anywhere.
Old Mar 31, 2017 | 10:27 AM
vbdenny's Avatar
vbdenny
Very good advise. Thanks.
Old Mar 31, 2017 | 10:42 AM
Sneakytoot's Avatar
Sneakytoot
Changed my batteries last week, 2014 NRB coupe, the car is stored about 40 miles away, so put new batteries in so I don't have a problem when I pick it up next week....
Old Mar 31, 2017 | 10:59 AM
fredmills's Avatar
fredmills
FOB is difficult to open. Take your time.
Old Mar 31, 2017 | 11:27 AM
dbdave's Avatar
dbdave
This is a good reminder for the '14 folks. Mine was new 4/14 and had to change the batteries before it went into storage last fall. Looks like the 3 years or so for batteries is about right.
From my experience, when I took a voltage reading on the old batteries, they were at about 2.6 volts so it doesn't take much before they become a problem.
Old Mar 31, 2017 | 11:47 AM
Curahee's Avatar
Curahee
I agree with all of the above. I just wish GM could design a fob that wasn't such a PITA to install batteries. Better yet, design one with lithium batteries that could be recharged via a USB port.
OK, enough bitching for now. Peace-Out.
Old Mar 31, 2017 | 12:18 PM
TEXHAWK0's Avatar
TEXHAWK0
I just changed mine on my 2014 and I was surprised that the second fob, that has never been used, also would not work.
Both would trigger the cannot locate fob message.
I had just had a re-program done on the air bag recall, and thought the car got messed up, but I guess that was just a coincidence.
Old Mar 31, 2017 | 01:24 PM
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
C7Joy: "I finally uncovered my car, ready to put it into service for another new year of fun. With my fob in my pocket I could not open the driver's door without hitting the unlock button. When I jumped in the car the instrument screen did not illuminate the way I am used to seeing it. I hit the start button and I got the Fob not found message. Ah hah! Battery time."
The exact same thing happened to me starting about a month ago with my '14 C7 (build 10/2013) in storage and still on a battery tender. Double checked both FOBs just now and both act the same. Only difference was after relocking to set security, both FOBs acted normally but only for about a minute. So battery replacemant time for both. Thanks C7Joy.
Old Mar 31, 2017 | 02:07 PM
owc6's Avatar
owc6
When changing fob batteries, make sure the fob is warm. This will help keep the fragile case from cracking as easily. Use the rounded key end to pry the case apart.
I also recommend doing this at home not in your lap in the car; there are small parts just waiting to spring apart and get lost.
Old Mar 31, 2017 | 02:15 PM
K9MF's Avatar
K9MF
Mine will be 3 yrs old tomorrow, April Fools day, and I just changed mine the other day. Hard to believe 3 yrs and 36K miles have gone by and the car has been great. Ya, it's a M7
SN 20599
Old Mar 31, 2017 | 07:19 PM
BILL88's Avatar
BILL88
Default key fob
same here, mine put in service Feb 25, 2014, 7,000 miles both fobs died last month.
Old Mar 31, 2017 | 07:26 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
Yes. Feels like you are going to break it. Just changed mine because it said "Service push button start system". 2015
Old Mar 31, 2017 | 07:44 PM
BELVIN20's Avatar
BELVIN20
I change mine yearly, easy to change, "follow owners manual", opening the fob is a snap. You use your key that is in the bottom of the fob to open the fob, 5 minute job, just follow owners manual.
To FOB batteries
