Error code P159F
Old Apr 1, 2017 | 06:13 PM
Marc DeSatnik's Avatar
Marc DeSatnik
Default Error code P159F
I have this on my 2014 Stingray.
Anyone know what it is?
TIA
Old Apr 1, 2017 | 06:53 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Engine Controls and Fuel DTCP159F or P15A0
Fuel Economy Mode Switch Circuit LOW or HIGH Voltage 159F is Low voltage
Center Console Switch ( Weather, ECO, Tour, etc) wire voltage is too low.
Seems to say the Multifunction Switch is going bad.
Elmer
Old Apr 1, 2017 | 08:53 PM
Marc DeSatnik
Elmer
The 2 switches on the lower dash, to the left of the steering column are currently not plugged in. Would it have anything to do with that?
Old Apr 1, 2017 | 10:15 PM
eboggs_jkvl
Moderator emeritus
Dunno, I simply read what was in Helms for the code.
Elmer
Old Apr 1, 2017 | 10:18 PM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
Plug them back in and see if it goes away
Old Apr 2, 2017 | 09:47 AM
eboggs_jkvl
Moderator emeritus
Um.... Seems to ask the question of "Why are they disconnected?" One is alarm related and the other is the rear hatch (I think)???
Elmer
Old Apr 2, 2017 | 09:53 AM
Marc DeSatnik
Elmer
Disconnected because i'm in the process of hooking up my navtool, alky control and laser jammer. i had to start the car and turn it around
one is trunk and i don't know what the other is
Old Apr 2, 2017 | 10:30 AM
eboggs_jkvl
Moderator emeritus
It temporarily disables part of the alarm system (Intrusion and Inclination Sensors Disable Switch. I think).
Elmer
Old Apr 2, 2017 | 01:34 PM
SnowyATX's Avatar
SnowyATX
Was removing a shifter the other day and turned on accessory mode with some cables disconnected under the console, including mode switch. Think I got this code and others. Put everything together and cleared them with scan tool and then gone. Freaked me out at first. ; )
Old Apr 2, 2017 | 05:58 PM
Marc DeSatnik
That's what I figured so I wasn't all that worried.
Just put on a supercharger so theyl clear the codes when I bring it in for a tune.
To Error code P159F
