Overheating issues
Old Apr 10, 2017 | 03:33 AM
Sloo_Dc2's Avatar
Sloo_Dc2
Default Overheating issues
Hey guys, I just purchased a 2014 1lt corvette stingray 3 weeks ago and have overheating issues, 3 days after I initially purchasing the car it overheated at idle in my garage and blew the rad. Cap off and coolant spilled into my garage and driveway. Dealership blames faulty thermostat and was fixed. 9 days later it blew off again at car wash and was sent to chevy to diagnos, was fine and car returned after rad. Reservoir replaced 10 days later. Now less than a week later car is still over heating, I think being under factory warranty the car is eligible for a dealer buy back. Any input would be appreciated.
Other than this issue car is absolutely immaculate with 19k on the clock.
Thank you.
Old Apr 10, 2017 | 03:56 AM
CGZO6's Avatar
CGZO6
What was your coolant temp reading? Was the radiator fan running?
There have been a few members that have had a warped coolant reservoir cap receptacle. Meaning that when the reservoir cap is installed, the reservoir is warped and the cap does not create a proper seal. This allows air to escape and the coolant system does not pressurize when the coolant gets hot. The coolant system needs to retain pressure to raise the boiling point of the coolant. Without pressure the coolant will boil at 212 degrees F. With pressure the boiling point will be about 260 degrees F.
If this is the issue, the dealership should have caught it during a pressure test of the system. But, could be easily be missed.
HTH
Old Apr 10, 2017 | 06:50 AM
GP1224's Avatar
GP1224
Drive the car back to the dealer and hand them the keys and tell them you want your money back or they will be hearing from your lawyer in 24 hrs. You don't want that car after it overheating so many times.
Old Apr 10, 2017 | 08:24 AM
b4i4getit's Avatar
b4i4getit
I would think that after 3 times of trying to fix the problem the dealer is not very good at diagnosing the problem. Pick another dealer and let them try to fix it. You have been more than patient. Don't let this experience affect your appreciation for the car.
Old Apr 10, 2017 | 11:24 AM
davepl's Avatar
davepl
The only good news I have is that there must be something specifically wrong with this car - it's not an issue that's borderline or crops up on a lot of cars. Once a good tech finds the cause and fixes it, it'll be gone.
Now the hard part... finding a good GM tech that can diagnose and fix it. They're out there, though!
Old Apr 10, 2017 | 11:44 AM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Take the car back! And don't pick it back up. You have a lemon.
Old Apr 10, 2017 | 11:49 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
I think you posted this in the wrong section of the forum.
Old Apr 10, 2017 | 03:37 PM
rti35's Avatar
rti35
Wrong section, but give that car back. You could have engine damage with all the overheating it's done so far
Old Apr 10, 2017 | 04:14 PM
DogTag-C7R's Avatar
DogTag-C7R
Let them look at it and don't pick it back up - they are in possession of it......then start the process of buy back - you will have slightly better leverage if they already have the car and you have no intention of picking it up - now that sounds good but i don't know your situation - if you need a car to drive then thats prob not acceptable - as i imagine it is a long process. I'm talking myself out of this idea now lol - could still be making payments while it sits there etc...I see your in Mckinney - What dealership did you take it to? I had a nightmare at eldorado - 500 mile oil change guy says i need new tires - he never saw cup2 tires before - then they put 60 miles on it joy riding - i escalated it to gm but got nowhere - try stone briar - i have had better luck there. You can speak to the tech etc....not some service advisor.
Old Apr 10, 2017 | 04:40 PM
Sloo_Dc2's Avatar
Sloo_Dc2
The car was purchased at Fiat/Alfa Romeo of Mckinney. I'm seeking dealer buy back.
Old Apr 10, 2017 | 05:52 PM
\Boost Monkey/'s Avatar
\Boost Monkey/
Won't work in Texas, you have (or original owner in this case) would have to have had this attempted to be fixed multiple times during the first year of ownership.
Once the first year passes, no go my friend. Ask me how I know (hint, A8)
Old Apr 10, 2017 | 06:34 PM
boostaholic786's Avatar
boostaholic786
Regardless, your issue DEF needs to get resolved. If I was you I would make the drive out to Grapevine to Classic Chevrolet. They have specific C7 Corvette techs that diagnose your car. Not a tech that sees a C7 and flips **** over it since he has been working on Malibus all day long
Old Apr 10, 2017 | 07:25 PM
Sloo_Dc2's Avatar
Sloo_Dc2
Thank you for the info, yea my attorney says I have a strong case but what would you recommend as far being able to show that the integrity of the motor has been compromised due to the continual overheating?
Old Apr 10, 2017 | 07:32 PM
10thumper's Avatar
10thumper
Let's start with the first step...
Do you have data logged showing the exact temperatures when the overheating occurred? How did you acquire this information and how reliable is the data? What are your credentials to perform such testing?
Now, one might simply state that they observed the temperature gauge in the vehicle. That's fine, although not quite scientific.
I'm not bashing you I'm just looking at how the dealer will approach this discussion.
Old Apr 10, 2017 | 07:33 PM
2fastnow's Avatar
2fastnow
There is nothing technical about it. If the thermostat works the car at idle would have no problems. Maybe someone hear knows better than I do but they still have thermostats right? If so that motor has a head gasket leak or warped head...it's a goner.
Old Apr 10, 2017 | 07:41 PM
Sloo_Dc2's Avatar
Sloo_Dc2
Ok I see, well the techs at GM should know once they hook the computer up to the ECU and that will provide them with the criteria they need or at least show them, hey! This car has overheated several times and then they go from there.
Old Apr 10, 2017 | 08:44 PM
NSC5's Avatar
NSC5
It could be a stuck thermostat, defective electric fan, faulty water pump, etc. Have a Chevrolet dealership run the VIN for service records to see what has been done to it.
If it is literally blowing the cap off then you may have a blown head gasket or other issue causing it to pressurize the cooling system and the dealer has a test kit that will indicate whether there are combustion gas byproducts in the coolant.
To Overheating issues
Old Apr 10, 2017 | 08:50 PM
sTz's Avatar
sTz
This was probably why the car was traded-in. I bet if you checked the maintenance history you'll see that the previous owner was dealing with the same issue.
Old Apr 10, 2017 | 08:54 PM
VetteDrmr's Avatar
VetteDrmr
How about something really stupid like a 30 minute compression test?
Old Apr 11, 2017 | 02:19 AM
Sloo_Dc2's Avatar
Sloo_Dc2
Yes so if they look up records and find out that's why the car was traded in.... Chevy is nearing breech of warranty.
