DIC issue
Old Apr 13, 2017 | 07:45 PM
gbjerke's Avatar
gbjerke
Default DIC issue
Where do I go with any issue??? Right here.
Here is my issue with the DIC. I have it always set to the display indicating "Miles til empty, V8/V4 mode, current MPG" etc. I can tab down to "oil life percentage" and one more down gives me "tire pressures".
PROBLEM: all I get now is "phone connected" or "phone not connected". I cannot tab up or down to get anything else. I have turned off my phone and shut down the Blue tooth but cannot get rid of this message.
Have little confidence in the local dealer so thought I would go to the best source....this FORUM!
Any help out there?
Old Apr 13, 2017 | 08:03 PM
defaria's Avatar
defaria
Hit the left arrow on the right hand side of your steering wheel. Then hit the up arrow until you are in "Info" mode. Then play around and see all the other functionality you've been missing and perhaps consult the manual.
Old Apr 14, 2017 | 01:27 AM
Grand Slam's Avatar
Grand Slam
To clear the phone connected window press the center button of the cluster where you usually press up or down to change displays. I think the phone display even tells you to do that if you look carefully (not absolutely sure of this).
Old Apr 14, 2017 | 01:54 AM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
try disconnecting the battery, short of that, see dealer.
Good luck.
Old Apr 14, 2017 | 09:48 AM
Foosh's Avatar
Foosh
When you receive a phone call on a paired phone, the DIC menu automatically switches to phone mode. On my '14, I have to hit the steering wheel left arrow and switch back to whatever display mode I want, (e.g. info, performance, nav etc.).
Old Apr 14, 2017 | 10:41 AM
Larry/car's Avatar
Larry/car
I think you are in the wrong info mode. Select the DIC mode by hitting the left arrow on the steering wheel selector to bring up the menu.
Old Apr 14, 2017 | 11:18 AM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
The childish side of me wants to say that based on the title of the OP this post reminds me that many people always ask me if the Corvette comes with a bottle of Viagra and if it did, it would solve the DIC issue.
Old Apr 14, 2017 | 06:03 PM
gbjerke's Avatar
gbjerke
BINGO!!! Thanks much for your input....and yes, I do feel like an idiot.
Am seriously tech challenged but knew I could come to this forum for a solution.
To DIC issue
