440 and counting....
Old Apr 22, 2017 | 05:01 PM
Myfourth1's Avatar
Myfourth1
Default 440 and counting....
Made an appointment for next Friday to do the 500 mile oil change. Still contemplating doing the differential and transmission fluid changes as well. I guess I'll make up my mind at the last moment.
Not bad....17.9 MPG. I averaged 17.3 on my 2014 Base 3LT.
Old Apr 22, 2017 | 05:05 PM
Foosh's Avatar
Foosh
Anything other than the oil in a dry sump car would be totally silly at 500 miles.
The only reason for that is that GM found that while the silicon seals in the engine were curing they put residue into the oil that compromised the oil's anti-foaming properties somewhat. It's no big deal in a wet-sump car, but in a dry sump car, any foaming oil can find it's way into the air intake.
It was a precaution added after some of the early cars showed signs of that.
Old Apr 22, 2017 | 05:11 PM
Myfourth1's Avatar
Myfourth1
I tend to agree with you on the diff and transmission fluids. And yes, I am aware of the foaming issues and the need for the 500 mile change, thanks.
Old Apr 22, 2017 | 05:54 PM
twowinns's Avatar
twowinns
Why are you at home posting about your mileage? Get out there and give your car (and you) those precious 60 miles, and change that dealer appointment to Monday!
Old Apr 22, 2017 | 06:21 PM
dbaker's Avatar
dbaker
I did the trans fluid (M7) change myself shortly after 500.
It was a very metallic/silver red.....typical of new gears breaking in.It also seems to be approx 1/2 qt low.
Car was eyesight level,so close enough.
Shifts much better now.( fluid meets spec)
The diff fill plug is a PITA to get to.May have the dealer do it.
\db2
Old Apr 22, 2017 | 06:48 PM
Myfourth1's Avatar
Myfourth1
I just got back from a 50 mile ride to get it to 440. I'm busy until next Friday and can't get to the dealer so I'll eek out another 60 miles between now and then. It's a dirty job but someone has to do it.
Old Apr 22, 2017 | 08:06 PM
twowinns's Avatar
twowinns
Iif I lived closer, I'd volunteer to finish off those miles for you, take it to the dealer, and have it ready to go for you on Friday.
Old Apr 22, 2017 | 08:20 PM
70mack's Avatar
70mack
2nd Gear
corvette
Old Apr 22, 2017 | 08:31 PM
BooSSted's Avatar
BooSSted
Mmhmm
https://www.corvetteforum.com/forums...iff-fluid.html
Old Apr 22, 2017 | 11:55 PM
Foosh's Avatar
Foosh
Yeah, car forum 101. You could do a blind test of putting fresh fluid in unbeknownst to an owner, drain and show it to them after 50 miles, and they'll tell you how nasty it was.
To 440 and counting....
