PDR volume using Cosworth tool
Old Apr 23, 2017 | 06:45 PM
Vinvette04's Avatar
Vinvette04
Default PDR volume using Cosworth tool
I do have any volume when watching my PDR recording while using Cosworth toolbox.
Is there volume using the Cosworth toolbox??
Old Apr 23, 2017 | 07:25 PM
BEZ06's Avatar
BEZ06
Yes - there should be sound.
Do you have a Mac??
There have been lots of threads about no audio when playing the PDR files with QuickTime. Take a look at this thread:
https://www.corvetteforum.com/forums...-solution.html
If you are using a Windows machine you shouldn't be having any problems.
Do you see all your data when viewing a file with Toolbox?
If you've done any editing of your original PDR video file, it won't open in Toolbox.
Old Apr 23, 2017 | 08:23 PM
Vinvette04's Avatar
Vinvette04
I have volume in quick time and windows, my main operating system is windows.
I meant to say; the problem is NO volume in Cosworth, all the data performance details are in there.
Old Apr 23, 2017 | 08:41 PM
NSC5's Avatar
NSC5
Sometimes you get odd things happening with the audio software used with your PC. I use a HP Z820 workstation as my desktop PC and when Cosworth toolbox is active the audio device manager provides a separate volume setting for it in the audio mixer software.
Try right clicking the speaker icon in the Windows status area in the lower right corner and check those settings.
On edit: It is unlikely you made the recording with valet mode active in your C7 but the PDR mutes audio recording in this mode in order to not violate state laws against audio recording of someone without their knowledge or consent. This was rolled out with later production and I think there was an update to remove this audio function during valet mode from earlier builds.
Old Apr 24, 2017 | 10:32 AM
Kenafin's Avatar
Kenafin
I can't use Cosworth on my pc. Something with the audio codec's it wants to use and my system don't play nice together. The file will play but I get no sound. I get sound if I play the file outside of Cosworth so it's not the file. I did some minor troubleshooting but it reached a point where I didn't want to bother - it was just easier for me to install Cosworth on a different system.
To PDR volume using Cosworth tool
