Replacement tires
Old May 7, 2017 | 06:51 PM
jim85's Avatar
jim85
6th Gear
Default Replacement tires
What are folks replacing their OEM tires with on C7 Z51
Old May 7, 2017 | 07:16 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Consumer reports rates the OEM tire #1, so I decided to replace mine with the OEM Michelin.
Old May 7, 2017 | 07:19 PM
JK 23112's Avatar
JK 23112
I only have 1300 miles on my car, so I hope I won't be buying tires for a long, long time. From what I have heard from other Corvette owners, I should expect about 15,000 miles out of the first set (19" rear & 18" front -- Stingray without the Z51 package).
One of the tough things is that the tires are unidirectional and are different sizes -- thus meaning they cannot be rotated the way it is with more "typical" cars.
Old May 7, 2017 | 08:12 PM
buckeye4's Avatar
buckeye4
Well they are not unidirectional and can be rotated left to right and right to left, but not front to back or back to front because of the size difference. They do have a outside and inside that should be noted for proper mounting.
Old May 7, 2017 | 09:41 PM
MeHeartCorvettes's Avatar
MeHeartCorvettes
The stock tires absolutely can be rotated and per your owners manual, should be. Obviously, due to front and back being different sizes, front left and right rotated as a pair and the same for the rears.
Old May 7, 2017 | 10:04 PM
rkhegler's Avatar
rkhegler
Best bang for your buck. I have them and like them.
https://www.tirerack.com/tires/tires...el#testResults
Old May 7, 2017 | 10:10 PM
thill444's Avatar
thill444
The OEM tires are my recommendation. Very good tire for the money.
Old May 8, 2017 | 03:10 AM
JK 23112's Avatar
JK 23112
How can you rotate an asymmetrical tread without dismounting & remounting the tire? Wouldn't the tread be "backwards" if you didn't?
Old May 8, 2017 | 07:41 AM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
You would have to dismount and remount to flip them around.
I just replaced my OEM runflats with the same tires on my Z51 - with alignment came out to just under $1600 out the door. A little painful but I did get 29,000 miles out of the first set.
Old May 8, 2017 | 08:15 AM
rrsperry's Avatar
rrsperry
By the time most of will need to buy tires, the PS5 or 6 ZP's should be out..lol
Old May 8, 2017 | 08:37 AM
JK 23112's Avatar
JK 23112
Oh, that makes sense.
By the way, 29k is darn good.
Old May 8, 2017 | 08:51 AM
C6 MoneyPit
Yes a bit unusual I think because I do 80 miles a day commute on the freeway, in traffic, so not much spirited driving possible (or tire wear) there! LOL
Old May 8, 2017 | 10:49 AM
papillion's Avatar
papillion
Default Red Rider
For a Silver Lady.
To Replacement tires
