Dash cluster does not change
Old May 9, 2017 | 12:46 PM
dinows33's Avatar
dinows33
Default Dash cluster does not change
I have a 2015 and whenever I would change the driving mode the dash would change to a different mode. Now it is the same no matter what mode I am in, It stays the "clock face" Did I touch something that keeps it from changing
Thanks Deano
Old May 9, 2017 | 12:53 PM
NSC5's Avatar
NSC5
Thanks Deano
You need to link the instrument panel setting to Driver Mode so that when you change driver mode with the console **** the display view will follow. If so, to link (or unlink) from driver mode you use the arrow keypad on the right side of the steering wheel:
Press left arrow to bring up menu in DIC
Press down arrow to scroll through choices to highlight "Settings" and press SEL to select
Press down arrow (or up arrow) until you get to "Display Theme"
Press right arrow to open menu of choices
Use up or down arrow to select either link to driver mode or select a theme.
