Novistretch mirror covers
I bought the Novistretch front bra and mirror covers.
Is it me or are the mirror covers a real PITA? You are supposed to tuck the edges in around the mirror glass and I find this to be very difficult and very time consuming.
The ones for the C7 are a different material than the ones I had on my C5 which were very easy to install.
Anyone have a picture and/or advice for installation?
Received 7,753 Likes
CORVETTE TODAY Host
St. Jude Donor'15
It's not you....I have the same thing. They are a PITA to get on-I've almost given up on them.
Yes they are a pain but with practice it does get easier. Use a credit card to push the netting under the mirror. Also if you start with the mirror fully rotated up, it makes it simple to push the netting under the mirror at the bottom. Then just keep moving the mirror to open the gap up....I have it down to just a couple of minutes for each mirror. Good luck
Friend of mine has them never uses them says its quicker to clean the bugs off
JerryU (05-15-2017)
Second set, second vette...use one of those thin plastic discount cards usually stuck to a page in a magazine makes a perfect ARC to tuck around the mirror...indeed practice makes it easier...
I was ready to burn the mirror covers but I found the best and easiest way to install them. You go to your mirror control and turn the mirror out, driver's side, so the mirror nearest the door is out as far as possible. This leaves a large space between the mirror and the mirror closure. Then put the cover on from that end and stretch it over the rest of the mirror toward the out side of the mirror. Then go back to the control and slowly close the mirror. I used a plastic comb to guide the rest of the cover inside the mirror opening wedged between the mirror and enclosure, and gradually close the mirror itself until it's in the proper viewing position. Then repeat the process on the other mirror, the passenger side. I know it's hard to explain but it's the easiest way to install them. Good luck!
Radio_Q : Ditto but tried them a 2nd time and threw them in the trash. Life's too short for stuff that really does not work.
I had clear bra put on my mirrors...Soooooo much easier and better
