Wheel Certification : What's it mean ?
Is it possible to cheat, certainly, but it is illegal to use those stamps unless there is documentation that a manufacturer has tested and passed the certification criteria for JWL, TUV or both. VIA is supposed to mean that a wheel manufacturer has been audited at some point.
The purpose of the standards is to ensure that they meet a certain wheel safety standard, and theoretically should be more resistant to damage, of higher quality, and hence safer. That doesn't mean a nasty pothole won't take out a JWL/TUV-certified wheel even it's legit.
However, as we all now, cheating goes on all the time, and perps don't always get caught. It's not a guarantee, but it's better than no standard at all.
You asked if it's possible to cheat, and the answer is yes. However, generally speaking I don't think that's common. But yes, an established, name-brand, wheel manufacturer is very unlikely to cheat.
There aren't a lot of wheel manufacturing plants, and most make wheels for both well known brands, as well as off-brands. JWL/TUV standards are really minimum standards, which most big plants meet. The most expensive forged monoblock wheels far exceed JWL/TUV standards.
"Top notch" wheels are forged monoblock wheels, which are carved out of single blocks of forged aluminum. They are the lightest and strongest wheels available and usually cost at least 3X what C7 OEM wheels cost.
See that often on Chip Foose TV show (and some other car shows.)
He designs a wheel and like some aircraft parts, that large round block, about the width of the wheel, is put in a CNC machine and some time later after multiple tools make 80+% aluminum chips emerges a finished wheel!
Found this pic of a more efficient manufacturing process than the one-of custom wheel manufacture.
Stilll makes much more aluminum scrap than finished product.
So, to the question : what is the reputation of Vertini rf series. I see they also have an 'sf' series which I would think stands for spun forged ?
I can't confirm it, but a seemingly reliable source here stated that both the Z51 OEM wheels and the reproductions of same, were at one time manufactured in the same Chinese factory. The reproductions also have the JWL, TUV, and VIA stampings.
I think they were later sourced to a plant in Mexico.
Spin forging, or rotary forging on a low pressure cast wheel is just a supplemental process to shape the grain structure of the alloy on the barrels (only) closer to that of a true forged wheel.
In this instance, the wheel is still a low pressure cast wheel (the face) And the barrel only is spun forged to increase strength versus a cast barrel. Do not be fooled, you are still getting a low pressure cast wheel, but the barrel is spun very similar to what is done on a forged monoblock wheel. The issue for me is that wheels typically fail at the faces more, not as much at the barrel.
Think of it as a "low pressure cast wheel 2.0"
That being said, although the spinning process itself can vary among manufacturers, the general process is, in fact, similar to the similar step during the forged monoblock process. Think of it this way:
Forged face/spun barrel
Pressure cast face/spun barrel
Nope it's a Japanese wheel standard second to TUV in strictness.
Like exact dimensional specs via CAD models? FEA analysis results?
Exact types of molds and low pressure casting methods used? Exact pressure used on the mold? Data on the factories equipment? Sources and MTR's on the alloy used? QA/QC procedures?
None of us will ever get any of the above.
