Blind spot mirrors
Old May 25, 2017 | 11:37 AM
madmusicltd's Avatar
madmusicltd
Default Blind spot mirrors
So I am the new owner of a C7 convertible, both of the side view mirrors have blind spot mirrors attached on the outer edge of each mirror. Is this something from the factory, or something the previous owner installed? I am not really crazy about the look of them, and do not think I really need them, although the rear view is not optimal with the top up. I am thinking I may remove them if they are not a factory part. Thoughts?
Popular Reply
May 25, 2017, 11:46 AM
1SG_Ret's Avatar
1SG_Ret
Originally Posted by madmusicltd
I didn't think they were factory, they kinda take up too much of the mirror too... maybe for a truck or a camper huh...
Likely for someone that doesn't know how to adjust their mirrors.
Old May 25, 2017 | 11:39 AM
CP's Avatar
CP
Not factory.
Old May 25, 2017 | 11:40 AM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
Correct, not factory, if you don't like them simply remove them. There's been debate on here before as to if they are needed or not, personal choice.
You can use some fishing line or dental floss to go behind them and slice them off. Then clean up with some alcohol and a razor blade as needed.
Old May 25, 2017 | 11:42 AM
madmusicltd
Old May 25, 2017 | 11:46 AM
1SG_Ret's Avatar
1SG_Ret
Old May 25, 2017 | 11:47 AM
madmusicltd
I did see the post here on properly adjusting mirrors
Old May 25, 2017 | 12:24 PM
Larry/car's Avatar
Larry/car
The mirrors are power so you can move them around to see as required. They can be programmed to a predetermined setting when you put the transmission in reverse.
Old May 25, 2017 | 01:42 PM
madmusicltd
I set both of mine to drop in reverse, but I am thinking to change it to just passenger side, great feature to have... mirrors will be coming off tonight~
Old May 25, 2017 | 01:44 PM
mountainears
I couldn't get used to having it drop in reverse. I don't use memory seat position #2, so I just set a different mirror setup and I can press button 2 and it just moves the mirror.
Old May 25, 2017 | 01:57 PM
dvilin's Avatar
dvilin
Definitely not a factory item, not needed, ugly as well remove them.
Old May 25, 2017 | 03:47 PM
Rebel Yell's Avatar
Rebel Yell
May be able to heat them up with a hair dryer, and pull 'em right off. A little Goo Gone will take the rest of the sticky stuff off.
Old May 25, 2017 | 04:18 PM
springer-'s Avatar
springer-
The best adhesive remover I have found and use is lighter fluid. Just drip it on behind the adhesive and as it seeps in the mirror should slowly come off with a little pressure.
Even says it right on the label.
Old May 25, 2017 | 04:56 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
prior owner. years ago springer's idea was right; I guess it still is. should work. just be careful because you really don't want to break the mirrror behind those things, nor pull it off.
Old May 25, 2017 | 05:27 PM
cvwb's Avatar
cvwb
That's a great idea for me, and I never thought of it. With the smaller rear window in my convertible, and because I'm not tall, I can't see enough of cars behind me but I'd sometimes like to. For those times, I'll be setting my #2 position to move the side mirrors inward to show more of the rear view. Dynamite idea, so thanks.
Old May 25, 2017 | 05:28 PM
Crossed Flags Fan's Avatar
Crossed Flags Fan
Not a good idea!!! If you use razor blade to remove the stick on blind spot mirror on the driver's side you will remove the coating that darkens the mirror when it's dark outside.
Old May 26, 2017 | 02:19 AM
smajicek's Avatar
smajicek
My solution to blind spots, added some cameras to the side windows
Old May 26, 2017 | 09:31 AM
madmusicltd
No problem with the driver side thank god, the passenger side adhesive decided to stay on the mirror, rather than using lighter fluid, I chose WD-40, soaked it, then kinda used my finger nail to remove the remains, unfortunately I left some micro abrasions... that mirror surface material is not the hardest glass. Much better with them off!
To Blind spot mirrors
Old May 26, 2017 | 04:32 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Tis That!
Hmm, been using what folks refer to as "Properly Adjusted Mirrors" since the SAE paper in 1995 that defined "Put your head on the drivers window etc etc!" That is what the graphic below is based on - but you must read the right side in addition to looking at the pics.
The SAE paper discussed that in the multipage paper on defensive driving! If all folks are looking for is a way to see the cars immediately behind their rear fenders fine! But that is NOT defensive driving! In fact the "Blind Sport Detection" in the wife's BMW SUV only does that and is also not the best solution, IMO!
Below is why I used small oval "blind spot mirrors" in my C7, Z51 and particularly need and use one on the drivers side of my new Grand Sport! Perhaps this dialog will be useful for those who use them or want to use them and don't like the written abuse they get from some Forum folks who just discovered the "put your head on the window" method! They are like reformed smokers, IMO!
DETAILS:
First, never felt I needed or used them in my '88, '93, or '08 Vette coupes. The narrow view of the rear in the C7 coupe and especially my Grand Sport with a Stage 2 aero spoiler that limits rear view further! Almost as bad as a Vert!
Have never in 55+ years of driving had an accident with another vehicle! (Looking for wood.) Yep some of that is luck but also being aware of all vehicles around me. That requires an automatic habit of looking in all mirrors all the time. As that little clip below states "you MUST follow a car from the center mirror to the side mirrors." Could do that in my C6! Harder to do in my C7 and worse in my Grand Sport with Stage 2 spoiler that further limits rear viability accept directly in the center.
Why is that needed? A good example is a recent experience on I95 where I set my cruise control at 77 mph. Lots of beeps on my radar detector as I am in an area that catches folks coming from up North going to FL and we're the first big town after leaving NC! I fellow passed me in the left lane as if I was standing still, going at least 90 mph in an SUV. He was holding a cell phone in his right hand looking at it! Yep illegal even in SC if he was actually texting -a $25 fine if the trooper wants to go the court and "prove" he was texting! We still allow holding a phone to talk. But even if was arguing with his girlfriend (about his wife, ) he was distracted. Need to follow him as he is approaching from much further back that just my rear fenders.
I find it common for folks to do that in the right lane thinking they are using middle lane traffic of block radar! Need to check out both, just in case you need to move quickly.
That happened to me! I was in the center lane and a large 18 wheeler tire tread was in my lane. No time to turn my head. Had been looking in both of my driver's side large mirror (set per the graphic below,) my small mirror and the center mirror with it's limited view and knew there was no AH barreling down the left lane. Made a quick decision to change lanes and avoid destroying my carbon fiber splitter!
Your car your choice
but understand some of us who use "blind spot mirrors," do it for a reason!
Do I think blind spot mirrors or automatic blind spot detection are the best solution? NO!
We should be allowed to have convex driver's side mirrors as are allowed in Europe and on the passenger side mirror in the US! Just Sayin'!
Problem defined by the ~1995 SAE Paper is it Requires a Wide View of Rear. C7 Does Not Have a Wide View Like My C6. Must Read Words Underlined and Understand the Concept!
Old May 27, 2017 | 12:14 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Thats super cool.
How does that work? When you turn your left blinker on it turns on the left camera? How long doe sit take to show an image?
Old May 27, 2017 | 12:22 AM
smajicek's Avatar
smajicek
I purchased the navtool, it takes about 2 seconds to come on when I turn my blinker on. I use my blinker more often now than before because its so nice and I can keep my on on the road ahead.
