exhaust sounds
Old May 30, 2017 | 07:23 PM
teddycarnut's Avatar
teddycarnut
Default exhaust sounds
Is there a special way to change the sound increase. I turn the **** to eco, sports track etc. I don't seem to get lowder versions, what am I doing wrong thanks
Old May 30, 2017 | 07:35 PM
dbirdhouse1's Avatar
dbirdhouse1
Default don't quote me......
.... but changing the driving mode does not alter the exhaust note.....if you have the NPP option that will alter the exhaust note/volume but beyond that there is no other control......
Old May 30, 2017 | 07:42 PM
teddycarnut
Default ehaust
Yes I have the npp option
Old May 30, 2017 | 07:48 PM
oldC5's Avatar
oldC5
https://www.google.com/url?sa=t&rct=...7Ai9oUuPuibcBg
Look at this it explains everything.
Old May 30, 2017 | 07:52 PM
FLATJ's Avatar
FLATJ
Go to Settings on the infotainment screen. Touch Driving mode. Touch engine sound management. Play with it.
Old May 30, 2017 | 08:04 PM
mpuzach's Avatar
mpuzach
Keep in mind that with NPP there are only two sound levels - think of them as loud and soft. As FLATJ said above, the first thing to do is make sure under "Engine Sound Management" that it's set to "Link to drive mode". Doing so causes the exhaust system to switch between loud and soft based on drive mode-specific conditions. The specific drive mode selected determines the conditions under which the exhaust sound is loud or soft. If under Engine Sound Management a different setting is selected, switching drive modes will have no effect on what the exhaust sounds like.
Old May 30, 2017 | 11:14 PM
vbdenny's Avatar
vbdenny
Or, pull the fuse so the valves stay open. Not a whole lot louder, but enough. Saves you figuring out all the settings. #42 except on 14's. There is even a empty spare fuse holder to store it. Right passenger side midway through engine by fender.
Old May 31, 2017 | 12:07 AM
toolking's Avatar
toolking
Through the Engine Sound settings mine is set on Track 100%. Plenty loud, and the drone is not too bad. There's a few RV drivers on Hwy 93 in Nevada that will attest to the loudness.
To exhaust sounds
