Removing water spots from glass roof????
Like the title states. Anyone have any suggestions on how to remoce water spots from Lexan (plastic)?
Received 1,694 Likes
St. Jude Donor '15
That roof is lexan, I'm not sure I'd wanna use compound on it. Try Plexus, it's a cleaner/polisher designed for that stuff. It works really well.
Received 19,308 Likes
'20-'21-'22-'23-'24
I've used Adam's Polishes Glass Cleaner on my car (a C5) - has always taken water spots off.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The thread is mis-titled because it's not a glass roof.
CCA Corvette Parts (06-03-2017)
Novus makes several cleaners for Plastic can be purchased at most motorcycle shops or online I use them on Polycarbonate windshield on the Bike. Comes in small spray bottle
wipe it with a cool wet rag than use a detailing spray and clean rag to buff it to a shine.
I used to use Ducky water spot remover back in my JetSki days and it worked pretty well.
I'm backing the vinegar and water method as a starting point. Mild vinegar solution should remove any calcification. May need to do it a couple times but spray, let it sit for a few minutes, then wipe with a good towel. What could be easier?
Mike
Mike
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
WADR, first, know your product. Second, yes, you'll get lots of ideas on here, some of which would be wrong. Third, as at least a couple have said, look up the actual name of the product your roof is made of, Lexan. And look what you will find---products that clean Lexan.
https://www.google.com/search?q=lexa...hrome&ie=UTF-8
Finally, there's even a thread from a mfr. of the product saying, this is how to clean it:
http://ameriluxinternational.com/Sid...t_cleaning.pdf
Good luck.
Good luck.
