I am now an A8 victim
#61
I do have to smile when I read about the "bulletproof A6". The reason is I had a 2006 A6 Monterey Red coupe that I ordered and it was delivered in January 2006. I was driving in a local 4th of July parade going about 1 mph when to my utter embarrassment the tranny crapped out at the end of the parade. I managed to limp several miles of stop & go to the dealer's but they were closed since it was a holiday. So my buddy followed me and we left the wives there while he drove me home to get my other car. Meanwhile several people had been there and opened the door and pushed the car in. Later the following week they called and told me they'd put in a new trans along with the computer. Seemed the whole assembly is held in place with a snap ring which broke. Anyway they fixed it and paid for everything. But I can't tell you how many people said what a POS trans the 6 speed was and I should have never bought it. Well I kept that car until March 2014 and just so you know I ran mostly at Englishtown's Corvette Challenge along at Atco and at Maple Grove all told over 200 1/4 runs. Never had any other problems with that trans. My point is, there's thousands of A8's out there with out any problems that are getting hammered every day. I'm sure that GM's motivated to fix them all ! So do they need an overhaul or re design ? I don't know but would guess yes. However, to read some of these posts and speculations that are over the top doesn't really solve anything. If there's any that have been fixed, then you have to surmise that GM's on the right track.
#63
I took the car to the dealer and took the service manager for a ride and showed him what the car was doing. As the car began to shutter and the tachometer bounced up and down a couple of hundred RPM's during the ride, he didn't think that was abnormal. He said that if there was an issue, the check engine light would come on. He thought there might be a slight engine miss but not anything to be too concerned about until the check engine light would come on. I tried to assure him that the car didn't begin to do that until very recently. They are going to do a couple of tests on it tomorrow and have a technician check it over. I don't have a good feeling about it.
Several years ago I had a CEL in my 2006 GMC Sierra that was illuminated prior to even starting the truck. It started and drove normally but once started the only way to shut off the diesel engine was to pull the ECM power relay. The only stored DTC was for loss of communications between the engine and transmission controllers and I traced the problem to rodent urine which created a leakage path between switched and permanently powered 12 volt buses when the humidity was high enough. In many cases an illuminated CEL is the ultimate example of an "idiot light" because it doesn't come on for every readily observable issue and when it does come on the stored DTC(s) can easily lead the repair person down the wrong path. DTC(s) are a tool and not a replacement for a competent individual who still needs to have a basic operational understanding of the vehicle and its component subsystems.
#65
I think after reading this thread I'm going to buy me a Range AFM Disabler.
Guess I am lucky to not be experiencing the problems some of you are describing.
Maybe GM should just reprogram our cars so only Eco goes to V4. I wouldn't mind the recall at this point to correct this.
Maxie2U (06-05-2017)
#67
#68
It's almost too easy. All they would need to do is make a change in the TCM and/or ECM programming, so there must be a reason why they don't take this cheap approach. I suspect it relates to CAFE and EPA mileage ratings. Changes in EPA ratings have been done in the past after an audit revealed an error, but I believe all of those have been due to inaccuracies in manufacturers' ratings revealed after an EPA audit. In the present case they'd be changing the car's programming that will directly affect mileage. Maybe there would be penalties involved, higher than the costs of the TC repairs. Just speculating here.
#69
Comment:
Any owners of M7s or A6 C7s that think the A8 problem won't affect their re-sale value are not facing reality. Some buyers are not educated in the C7 and are not interested in becoming educated. They simply know the C7 has "transmission problems" and stay away from buying one. The only hope is that a cure is developed for the A8 that will solve the problem. It does seem like finding a way to avoid the V4/V8 change is the answer. Maybe an electronic bypass that prevents this automatic switch? Just guessing.
However, I'm not guessing about how the issue will affect all C7s.
Someday in the distant future when I sell my A6, if by some odd chance I run across and uneducated buyer I'm going to educate them real fast.
"Hey Mr. Buyer have you heard of a internet site called the Corvette forum?"
#70
For one, the o-ring issues that cause delayed engagement (#16-NA-014). That isn't related to the TC and my car also had this problem. GM chose not to fix it while the tranny was already out for the TC job because I couldn't reproduce the problem at a dealer. It was sporadic, and because of this decision the problem persisted. After two years of this BS I punted. With three years left in the drivetrain warranty I was covered, but there was no way I would keep that car after five years without an extended warranty.
#71
That particular dealer you cite is pathetically clueless and I would suggest going elsewhere. If that's not possible, insist that he read PIP5337E (or whatever the latest revision is, probably "H"), connect the car to a scan tool, and have a tech check it out.
#72
Foosh (06-05-2017)
#75
Just ordered the Range Disabler. Didn't take too long to make that decision. I'll let everyone know what I think once its installed and I've been using it for a bit.
#76
#77
You guys do realize that most likely GM will be putting the new 10 speed trans in the next year or two Corvettes. Hope they learned something but from what I hear the 10 spd (Joint venture between GM & Ford) is a big step forward. The biggest problem seems to be the cylinder deactivation. I'd just drop it if I were them. Just saying!
#78
I'm going to respectfully disagree with you there, someone buying a C7 will surely do their research on the car, I don't know of anyone who buys a car like this without doing his/her proper do diligence and I'm pretty sure one of the problems they will look for (or take into account) is the A8 transmission, they will ask if the tc has been replaced or not.......at least that's what I would do but then again I'm not your average car buyer, but an average car buyer does not buy this car used.
#79
Of those thousands I would suggest that many of those cars have the problem and the owner doesn't recognize it, or the problem will surface later. In the former example I can easily envision some owners thinking the shudder is caused by road imperfections, and the tach oscillations aren't noticed.
The problem is that many have been "fixed" for a while and the problems re-surface. Some have had their TC changed twice, and there are at least three revisions on the TC. Some 2017 cars are having TC problems, and that suggests to me they haven't gotten a grip on a fix yet, two years after these issues first started showing up.
And as we all know, the percentage of garage queens in the Corvette population is staggeringly high.
#80
2015's have the most examples of the problem because they are oldest and, on average, have more miles than a 2016.
2016's, on average, have more miles than 2017's, and show more of the issue than 2017's, etc.
