Help! Old Style Vitesse Throttle Controller Instructions Needed
Old Jun 10, 2017 | 05:30 PM
Z06pete's Avatar
Z06pete
Default Help! Old Style Vitesse Throttle Controller Instructions Needed
Please help, I need a copy of the Old Style Vitesse Throttle Controller.
The one with the two silver buttons in the controller and not the ****. If you have one you could e-mail me I would be greatly appreciative.
Thanks in advance
Pete
Purple Heart Recipient
PM me if you can help Thanks
Old Jun 10, 2017 | 06:08 PM
Patches's Avatar
Patches
Instruction on how to install:
- Switch off the car for at least 5 minutes and key off.
- Make sure the car is on the Parking position or Neutral.
- Push your driver seat all the way to the back to give you enough room to access under the dashboard.
- Unplug the Harness on top of your Gas Pedal (First you will need to push up the securing gray pin, after that while squeezing in the middle of the harness, pull the harness upward by holding the plastic connection, not from the wires!
- After you've removed the harness, now you can plug the harness that comes with the controller, male to female and female to the Gas pedal harness.
The optional yellow and blue wires on the main unit will not be used now (Brakes / Launch Control option) Instructions on how to setup the Controller: Setting up the Controller to be recognized by the ECU takes less than 1 minute.
- Make sure all cables / harnesses are perfectly connected. - Turn the ignition to the ON position without starting up the engine.
- Press and hold simultaneously the 2 buttons ( A + B ) on the Controller's remote until a count down is finished ( 3 - 2 - 1 - 0 ) then the letter L and a digit next to it ( Low voltage value that indicates the Gas pedal is all the way up.
- Now press the left button (A) once, it will show H and a digit next to it ( High voltage value ), now you need to press the gas pedal all the way down with your foot, while still holding it down push again (A) once and it will show 100.
Your new controller is now setup.
Turn the key to the off position and remove the key.
How to use our Throttle Controller:
B (Sport mode button) increases the Throttle's response: SP0 being stock all the way to SP9 being the highest setting.
A ( Economy mode button ) decreases the Throttle response ( It opens the Throttle blade in a way to help you save Gas. EC7 being the most economical mode.
Old Jun 10, 2017 | 06:16 PM
Z06pete's Avatar
Z06pete
Thank You, Thank You, Thank You for your help
Pete
To Help! Old Style Vitesse Throttle Controller Instructions Needed
