Do the inside exhaust tips really do anything?
Old Jun 22, 2017 | 10:20 AM
gixxerbill's Avatar
gixxerbill
Default Do the inside exhaust tips really do anything?
I mean they are always a pretty chrome color while the outside ones get black as soot.
Old Jun 22, 2017 | 10:24 AM
kenownr's Avatar
kenownr
If you run in stealth mode for awhile they will get black and dirty like the outside in sport and track mode.
Old Jun 22, 2017 | 11:28 AM
Larry/car's Avatar
Larry/car
With the base exhaust, all pipes receive their equal share and are always dirty.
Old Jun 22, 2017 | 11:30 AM
Kracka's Avatar
Kracka
Those are the baffled tips, where the outer tips are the straight-through ones when the NPP valves are open.
Old Jun 22, 2017 | 11:38 AM
gixxerbill's Avatar
gixxerbill
oh that must be what it is. I always run in sport.
Old Jun 22, 2017 | 02:46 PM
kenownr's Avatar
kenownr
Yes I'm pretty sure it is. I pulled fuse 42 for awhile and the outside tips were always dirty the entire time. I put fuse back in and ran in sport/track and the inside got a little dirty
Old Jun 24, 2017 | 12:14 PM
wgood's Avatar
wgood
There stainless exhaust not chrome !!! Wayne
Old Jun 24, 2017 | 12:30 PM
aj98's Avatar
aj98
If you have NPP and you haven't pulled the appropriate fuse,
then depending on how you drive,
the inside ones do most of the "work" (since the outside ones are only open above 1700rpm)
Old Jun 24, 2017 | 03:05 PM
///ADMAN's Avatar
///ADMAN
Then my outside ones must be always open
Old Jun 24, 2017 | 03:17 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
The inside pipes do most of the work forcing exhaust through a baffled muffler when cruising and slower driving. However with NPP the outside pipes open at higher rpms depending on drive mode setting and then bypass the muffler.
As I recall, in addition to opening from ~1500 to ~2000 rpm the outside pipes also open on start up. With the rich starting mixture and condensed exhaust water on cold pipes they add to the black soot.
Old Jun 24, 2017 | 05:36 PM
Mike Campbell's Avatar
Mike Campbell
There's such a nice invention called a "paper towel" which when used will solve your obvious dilemma!!
Old Jun 24, 2017 | 08:05 PM
JerryU's Avatar
JerryU
Ah yes, but some folks want to know why things happen, not just how to solve the issue after it occurs!
I believe that is the case with the OP!
PS: I find a rag and waterless wash spray or Turtle Wax Tar & Bug spray works well on the tips. Use the same spray with a microfiber cloth to clean "stuff" off the car's rear! 1st white car I have owned-dirt shows much more! Built a small wood shelf that holds the spray bottles with hooks below to hold the rags/cloth that is attached in the space between the garage doors.
To Do the inside exhaust tips really do anything?
