Remote vehicle start
Old Jul 30, 2017 | 10:50 AM
ROD BROWN's Avatar
ROD BROWN
Default Remote vehicle start
My 2016 came with the remote vehicle start and I am curious. The remote start works fine,but when I enter the car,I have to shut it off and restart it to move the gear shift into reverse or any other gear.Is this normal? Thanks for any replys,Rod
Old Jul 30, 2017 | 10:58 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Well, I get in, put my foot on the brake, Press the START button, this moves the seat into position and I'm ready to drive off WITHOUT restarting the car.
Elmer
Old Jul 30, 2017 | 11:33 AM
curve65's Avatar
curve65
I do the same as eboggs above.
Old Jul 30, 2017 | 12:30 PM
DogTag-C7R's Avatar
DogTag-C7R
Brake pedal and start button are your friend - while the owners manual may be quicker solution and your BEST FRIEND!
Old Jul 30, 2017 | 12:36 PM
cvwb's Avatar
cvwb
Elmer
^^^This. If you hit the start button without your foot on the break, you'll just shut off the car.
Old Jul 30, 2017 | 12:58 PM
Power Hawk's Avatar
Power Hawk
Like a couple other folks have said, put your foot on the brake, push the start button, and let the good times roll. I'm glad you posted this. I forget about the remote start button sometimes. That's the only way I can hear that great sound. I'm gonna try and remember it later today.
Old Jul 30, 2017 | 01:00 PM
ROD BROWN's Avatar
ROD BROWN
Default Clarify the sequence
I activate the remote vehicle starter,enter the car,depress the brake pedal,but the car won't allow me to put the shifter into reverse or any other gear. I shut the engine off and restart the vehicle with my foot on the brake and it works normal. Hope my explanation is clearer.thanks guys,Rod
Old Jul 30, 2017 | 01:05 PM
eboggs_jkvl
Moderator emeritus
Starting the Engine Using Remote
Start
1. Press and release Q on the
RKE transmitter.
2. Immediately press and hold /
for at least four seconds or until
the turn signal lamps flash. The
lamps flash to confirm the
request to remote start the
vehicle has been received.
During the remote start, the
doors will be locked and the
parking lamps will remain on as
long as the engine is running.
The engine will shut off after
10 minutes unless a time
extension is done.
3. Press the brake pedal and select
the ON/RUN/START
ignition mode.
From the owner's manual.
Old Jul 30, 2017 | 01:34 PM
budgreen3564's Avatar
budgreen3564
Don't try to put it in gear until you've hit the start button with your foot on the brake
Old Jul 30, 2017 | 01:56 PM
speedlink's Avatar
speedlink
Start
RKE transmitter.
extension is done.
the ON/RUN/START
ignition mode.
Isn't it great to read the owners manual! I wondered why they even bothered to print it and give us one. Wow, who would have thought you could find out how to operate the vehicle??
Old Jul 30, 2017 | 02:41 PM
speedlink's Avatar
speedlink
Yes,I am guilty of scanning through the owners manual.I deserve 10 lashes with a wet noodle on the rump.
Rod
Wasn't trying to flog you at all. Just a pet peeve of mine. All is good.
I just grow very tired of so many not reading and asking questions to obvious answers.
This is a great forum, with soo many great insights. I try learn every day.
Old Jul 30, 2017 | 08:12 PM
blkvet6's Avatar
blkvet6
Elmer
eboggs is correct.... seems strange hitting the "Start" button while the car is running (and you're not wanting to shut it off), but you'll get used to it. It's a safety/anti-theft feature so that the correct fob has to be in the driver's seat before the car can be moved.
Old Jul 31, 2017 | 12:36 AM
smajicek's Avatar
smajicek
I am with you speedlink, I studied the manual before my vette was delivered. Online pdf download. knew a lot when I drove off the dealers lot.
Old Jul 31, 2017 | 10:56 AM
CP's Avatar
CP
Start
RKE transmitter.
"Q"???? My RKE doesn't have a Q on it. It does have a circular arrow that is pushed for remote start, however. Car will not remote start unless locked.
Old Jul 31, 2017 | 03:22 PM
eboggs_jkvl
Moderator emeritus
"Q" & "/" are symbols in the owner's manual that did not copy and paste. I was too lazy to screen capture the information so the pretty pictures showed.
So, since you need pictures, here ya go!
Elmer
To Remote vehicle start
