MGW Shifter or Vitesse Throttle Controller
I'm waiting on my Ported Throttle Body from Tony Mamo and my Cold Air Intake from forum member Rooster to see how that effects my lag....
Am very interested in the Vitesse system though.....little nervous about it as well....
Dont mind my factory shifter at all......
The reality is that the shifter is just a stick, with either a spherical bearing or a trunion design bearing, so the main variable is where to put the pivot point.
The stock shifter really does function just as well as the aftermarket shifters. I mainly got the Hurst shifter because I like the old school styling of the rectangular chrome stick and round ball.
Even the MGW has some design features I do not really like, for example they replace the lower box with an open bottom rather than an enclosed box to keep out debris like the stock box.
Another reason I just changed out the top part of the shifter, and it works fine.
I think what we have here is another case of placebo effect. If you spend a lot of money on something, and go to the effort of installing it, you're pretty much guaranteed to think its a big improvement. Of course, there are always exceptions to that principle.
Precisely, if you want a shorter throw, it's a simple matter to find a shift **** which lowers the height on the OEM shifter shaft. As I've said before, I've had MGW shifters before, and they are nice pieces, but are no better in this case than what comes in the C7.
I think what we have here is another case of placebo effect. If you spend a lot of money on something, and go to the effort of installing it, you're pretty much guaranteed to think its a big improvement. Of course, there are always exceptions that principle.
i installed the mgw shifter on mine just because it gives the shifting more "feel" to it and i had a problem getting use to the oem shifter fully engaging 1st gear. other then that i think the oem shifter is not so bad...and the lag does kind of suck
That's exactly what I did w/ a weighted ****, and the extra mass reduces the effort. It's fundamentally the same thing the MGW does, but it can be done w/ the stock shifter for less than $100, and without taking your console apart.
dbintegrity (08-02-2017)
FWIW the Vitesse does nothing to actually improve the engines ability to process more air. Peak power and torque has not changed at all.
A ported TB adds about a 100 CFM that your hungry blower can grab and process into more power and torque (12-15 at the tires).
You still get the benefit of eliminating the lag with the ported TB and dramatically enhancing the throttle response but you also get a big perk of making a bunch more power with the added airflow the better shaped more streamlined TB provides. I have helped a few guys that have swapped out there Vitesse with my ported TB and all of them liked the TB better as there were real power gains in addition to all their other issues being resolved. Its a much better allocation of your modding money
Im a fan of MGW shifters also (installed one in my C6Z)....the right answer is to buy both....a ported TB and a shifter.....it's peanuts when you consider the cost of the car your considering modding
If your interested in the TB, shoot me a PM and we can discuss it in more detail. There are countless dozens of happy customers on this forum I have helped if you search (assuming your unfamiliar with this mod)
Regards,
Tony
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Former Vendor
MGW all day long! The shifting is greatly improved and it looks awesome.
I am not a fan of the throttle controllers as they do absolutely nothing for performance and 9 times out of 10 they cause issues at some point. If you want to improve throttle response get a factory CNC ported VMAX throttle body.
Kind regards,
Kind regards,
Agree, the MGW was an enhancement in the C6Z, and I did that MGW upgrade. However, the C7 OEM shifter is way better, and as I said above it's easy to shorten the throw of the OEM, which I'm totally happy with now that I've done that.
I also agree with your observations on the Vitesse. It just changes how much and how sensitive the throttle pedal is, thus how much one has to push to get the desired power level. Some folks seem think there's more power there because they barely have to touch the throttle before something happens. There isn't more.
Foosh, can you hook us up with the link to your short shifter pls? I wanna check it out.
Check here for the metal ****
https://www.twmperformance.com/shift...e-r-shift-****
Foosh (08-02-2017)
It's also weighted, 1.3 lbs. to be exact. The height was reduced from 5" (OEM) to 3.5", which results in a significantly shorter throw. The mass of the **** compensates for any extra effort inherent in a shorter lever throw. The shorter the throw, the more precision in hitting the gates, much like aiming at a target from a shorter distance.
That's basically pretty much what all shorter than OEM shifters are accomplishing, but this allows you to do it in 5-10 minutes for a lot less money.
It's just geometry and physics . . .
#33
I had the Vitesse on my M7 and hated it. While the idea was good, the throttle tip in was underivable over a setting of 2. Think of a 16 yr old who always gave too much gas and massaged the throttle while coasting along. The Vitesse went from 0 to 15 or 20% throttle which was extremely annoying. I sold mine.
I installed an MGW last week and I'm quite pleased. I found the stock shifter to be generally fine. But after experiencing the MGW, I'm sold on it. More crisp shifting and 5/6/7 are easy to feel and find.
No brainer. MGW is the right choice here.
#34
Thanks for the info!!
