Exhaust module failure
Old Aug 3, 2017 | 01:36 PM
PhilBurn1's Avatar
PhilBurn1
5th Gear
Default Exhaust module failure
Just bought my first Corvette 2017 C7 LT2.
Check engine light came on and the exhaust made a noise I would expect from a 1957 Impala. Dealer replaced and 5 miles later it happened again. whats up with this car??
Old Aug 3, 2017 | 04:18 PM
kenownr's Avatar
kenownr
Isn't a whole lot to fail in the exhaust system? A little more detail would be helpful. Do you have NPP - performance exhaust? What did dealer replace? etc. etc. etc.
Old Aug 3, 2017 | 06:01 PM
NSC5's Avatar
NSC5
Probably an AFM noise control valve; they are a problem in track use (one reason the Z06 doesn't have them) but they normally don't fail in regular service. If it is failing due to heat I would suspect a cat on that side is also getting too hot.
To Exhaust module failure
